Power Window and Door Lock Swap
Power Window and Door Lock Swap Empty Power Window and Door Lock Swap
Post by ninja85 on Sun Mar 20, 2016 2:31 pm
Hi Guys, Quick Question. I am in the process of selling my complete Power window and lock setup to a guy with a 77 Monte.
My setup came out of a 77 Elcamino. It is to my understanding that this is a direct swap as GM used the exact same parts for
all the 2 door A Bodys. Can this be confirmed ?
ninja85
ninja85
Power Window and Door Lock Swap Empty Re: Power Window and Door Lock Swap
Post by Mcarlo77 on Sun Mar 20, 2016 3:02 pm
Yep...you're correct in that this will interchange with the Monte. I've pulled many of them.
Street Cred : 68
Post by thatfnthing on Mon Mar 21, 2016 9:15 am
Ditto. My rig came out of a 77 Cutlass. They're all interchangeable. FWIW the swap will go very easy if he has the Fisher Body manual and uses the procedure in there for regulator swapping.
Street Cred : 58
Post by ninja85 on Mon Mar 21, 2016 10:06 am
Thanks Guys. It has been some time I did this I wasn't 100% sure. I just wanted to make sure for my customer and that he was satisfied.
ninja85
ninja85
