source for shields
source for shields Empty source for shields
Post by RossK73 on Wed Mar 30, 2016 10:58 am
Hi folks - I am looking for a source for new door water shields without being gouged for shipping to Canada. They want $100 at OPG for the $17 parts! Mine are pretty well toast. Thanx, Ross
RossK73
RossK73
source for shields Empty Re: source for shields
Post by Joe73 on Wed Mar 30, 2016 11:23 am
Maybe use some 15 lb. tar paper or some stick on dyna-mat or GTmat.
Street Cred : 73
Post by thatfnthing on Wed Mar 30, 2016 12:14 pm
I'd also consider a plastic painters tarp from Lowes/Home Depot, and just cut to fit. You should be able to get both doors from one sheet. Then layer your jute or padding over that.
Street Cred : 58
Post by Mcarlo77 on Wed Mar 30, 2016 12:55 pm
Considering they used Kraft paper and about the cheapest fiber insulation they could lay their hands on from the factory, just about anything could be used and offer better water protection/sound proofing.
source for shields Doorin10
Street Cred : 68
Post by RossK73 on Wed Mar 30, 2016 2:26 pm
I'm thinking of that rolled foam that they use under click flooring - or would that just wick up the moisture? The tar paper would do the job as well Joe - thx. Mine only had the kraft paper on the bottom half originally - what insulation or jute are you referring to?
RossK73
RossK73
Post by Joe73 on Wed Mar 30, 2016 2:46 pm
My 73 only had Kraft as well. No insulation.
Street Cred : 73
Post by thatfnthing on Wed Mar 30, 2016 2:47 pm
The jute is what's in Steve's photo.  It's like a thick loose grey felt that the factory used for padding/insulation/sound deadening.  If yours was missing, I would think someone had opened that door up and removed it.  Mine had it from the factory.
I wouldn't use the padding for laminate floors.  I work with a lot of insulation contractors who do spray foam, and the word is that open-cell will suck up moisture like a sponge, which a lot of laminate floor padding appears to be.  Closed cell doesn't absorb moisture, but that'll be tough to find in sheet form -- the nearest example I can think of is Great Stuff.  Stick with the tar paper or plastic.
Street Cred : 58
Post by Limey SE on Wed Mar 30, 2016 3:41 pm
RossK73 wrote:Hi folks - I am looking for a source for new door water shields without being gouged for shipping to Canada. They want $100 at OPG for the $17 parts! Mine are pretty well toast. Thanx, Ross
http://www.ebay.com/itm/1973-1977-Chevy-Monte-Carlo-Malibu-El-Camino-Door-Panel-Water-Shields-2-pc-/381563551390?hash=item58d6f5be9e:m:mGAJOy7g_dJ117PK8OLAJdA&vxp=mtr
source for shields 12527912
Street Cred : 92
Post by Limey SE on Wed Mar 30, 2016 3:43 pm
Street Cred : 92
Post by RossK73 on Wed Mar 30, 2016 5:15 pm
yep some choices anyway. Thanx guys
RossK73
RossK73
Post by pila on Thu Mar 31, 2016 5:50 pm
OPGI includes insurance, handling, shipping etc, and it costs an arm & leg to get small parts from them....been there. I just don't use them for anything these days......
The small last order I had with them, the insurance cost was more than the part...
