Help Shift cable transmission mounting bracket
Post by SSTOOLMAN on Sun Apr 24, 2016 7:19 pm
I need help with this, I got from a shift cable mount bracket from a member that was susposed to fit my 73 turbo 400 but after trying to install it the mount holes that bolt into the transmission pan are about 5/16" short of lining up. I am guessing maybe it was from a turbo 350. I am kind of dead in the water with this. the only part I can find on line is for a 74 or 75. Does anyone have one?
or know where I can get one, Any help would be greatly appreciated!
SSTOOLMAN
Re: Help Shift cable transmission mounting bracket
Post by 73ss on Sun Apr 24, 2016 8:55 pm
I'll see what I have, it takes me a while to find stuff, in the meantime I don't see why one from a 72 or earlier wouldn't work, camaro, nova any of them, Should be readily available from one of the suppliers, opg, etc.
Street Cred : 10
Post by SSTOOLMAN on Sun Apr 24, 2016 9:17 pm
Great thanks for looking, the part doesn't cross reference to any of the earlier years the only one I have found is Manufacturer Part #: 9793193 which says its for 74 or 75 Chevelle turbo 400, why its different than 73, 76 or 77 I don't know.
http://www.ss396.com/chevelle/FCB-193.html maybe see if yours looks like this one. Thanks
SSTOOLMAN
Post by 73ss on Mon Apr 25, 2016 6:22 pm
I found the bracket & yes it looks like the one you have in the link. (As near as I can tell, the angle in the pic is weird) I'm not sure what the 73 only is about. I think I got mine from a dealer in the early 90's, It's not factory to the car. I would like to hold on to it if I ever go back to a 400 or get another project. I thought I had 2 but the other one is for the 350. The link I posted says 68~77. Looks like the one in you'r link. $55 bucks is a little steep as well for a simple hunk of metal..
https://www.opgi.com/chevelle/1973/drivetrain/shifters/G240151/
Street Cred : 10
Post by SSTOOLMAN on Mon Apr 25, 2016 7:52 pm
OK I understand how you want to hold on to it. The one from OPGI is on back order and their tech guy said it would probably be 30 days. Ill take a chance on the one above they say its 67-72 and 74-75. The tech guy said he had no Idea why 73 was excluded.
SSTOOLMAN
