Polyurethane body bushing kit?
G3GM :: G3 Tech :: Body
Post by DaveFury on Fri May 20, 2016 11:28 am
Did anyone ever have any luck w/ finding a Polyurethane body bushing kit? Fusick has rubber kits $279.00, link but I haven't been able to find any poly kits. Any ideas?
Dave W.
DaveFury
DaveFury
Street Cred : 4
Re: Polyurethane body bushing kit?
Post by chevellelaguna on Fri May 20, 2016 1:08 pm
I went through that dilema recently. I bought a poly body mount kit from Energy Suspension. The mount bushings were not the same diameter as the originals. Plus they were shorter, didn't come with any inserts. Was going to be a pita to make them work. I ended up getting factory ones from Ground Up. I have poly bushings throughout the suspension, the factory body bushings lasted 40 years so I figured I'm good for my lifetime with a new set. Poly body mounts would be too stiff kinda overkill I think.
The Ground Up kit sells the rad support bushings seperately. They come with hardware, the rest of the body mount kit, the bolts and washers are separate. Ground Up sent me the wrong size bolt kit, I just ended up buying grade 8 bolts.
Street Cred : 16
