A/C is up and running plus some oyther items installed
A/C is up and running plus some oyther items installed Empty A/C is up and running plus some oyther items installed
Post by Wallyuph on Sun May 22, 2016 7:25 pm
Well it was a good weekend. Finally got to some items to get finished on the Malibu.
Got A/C hose replace that end was leaking. I used a Vintage Air set up with the new LS set up.
A/C is up and running plus some oyther items installed <a href=A/C is up and running plus some oyther items installed Ac_tem10" />
Installed new power window regulators and motors. Had to run the new wire harness as they use reverse polarity for the motors and switches.http://www.nu-relics.com/ part number 47300-201
Installed NOS roof rail weather strips on both sides. I had metro molded ones and they are still in great shape but these originals are way softer.
Spent hours adjusting the windows.
Now I need to make a Appointment for window tint that I still have door panels off.
A/C is up and running plus some oyther items installed <a href=A/C is up and running plus some oyther items installed Door_p10" />
A/C is up and running plus some oyther items installed Empty Re: A/C is up and running plus some oyther items installed
Post by 73CopperMonte on Sun May 22, 2016 10:06 pm
Are you using original power window regulators or an aftermarket setup?
73CopperMonte
Street Cred : 4
Post by Wallyuph on Mon May 23, 2016 5:56 am
73CopperMonte wrote:Are you using original power window regulators or an aftermarket setup?
After market set up. Bolt right in.
