Wheel/Tire Questions
Page 2 of 2 Previous  1, 2
Re: Wheel/Tire Questions
Post by impalamonte on Tue Sep 27, 2016 12:09 pm
Hawk ,
Im running 255 / 50 / 18 all around on mine. My rims have 5.5" backspacing with +1 offset.
For comparison you could do..... dimension wise , yours vs. mine. To get in the ballpark.
I have no rub in the front but close lock-to-lock to the frame.
But keep in mind I also have the Impala spindles bringing the wheel assembly inboard slightly.
On the rear I probably could use some more tire inboard towards the frame before interfering with exhaust. .
Post by 73CopperMonte on Tue Sep 27, 2016 10:11 pm
Impalamonte, those 28" 255/50/18s look great all around. Just wish there was more options for tires in that size.
Do those 9.5 wheels have 5.25 bs?
I am thinking of using an 18x10 in the rear with 6" bs, and a 295/45/18.
73CopperMonte
Street Cred : 4
Post by alowerlevel on Tue Sep 27, 2016 11:54 pm
Hawk03 wrote:Before I order tires I want to confirm on the correct size. The front whees are 18x8, BS 4.50 and 0 offset and the rear wheels are 18x9.5, BS 5.5 and +6 offset.
I was going to go with 245/40/18 in the front and 275/40/18 in the rear. Would these fit without any issues?
Those should fit fine Thumbs up
You can always compare against your current wheel/tire combo to double check here--> https://www.rimsntires.com/specspro.jsp
alowerlevel
Street Cred : 6
Post by impalamonte on Wed Sep 28, 2016 1:39 pm
Copper ,
Your correct. My mistake.
5.25" backspacing on those wheels.
I've done so much in the last few years I mostly forget a lot of the details.
