74 Wagon LS swap
Page 1 of 1 • Share •
74 Wagon LS swap
So hey guys I got a 6.0 and 4l80e from a 2500 chevrolet. I need help figuring out how these things will go in to this car. I know I need a pan, I know I will need engine mount adapters, but which ones? Also, will the trans be fine? Do I need to relocate the crossmember? Also is there a fuel sending unit I can use from a late model car that will work in the wagon gas tank and put out enough pressure? Thank you guys in advance, help is appreciated.
a-body- G3GM Member
Re: 74 Wagon LS swap
well guys i done gone and did it so if yall got any questions let me know
ended up putting a laguna nose on it, doesnt fit very well at all. Super fun to drive though
a-body- G3GM Member
There is a really good write up on installing a Laguna nose over on El Camino central.
Should probably grab a Windstar or 90s F-body double fan setup with a Volvo controller instead of that huge A$$ shroud
brownbomber77- G3GM Member
I would but I love the crazy amount of air the stock truck fan and clutch pulls. When it's cold it sounds like driving a jet
a-body- G3GM Member
» 73 camper special 454
» Chevy Performance SP350/357
» Frame Bracing
» olds rear axle
» 73 SS - Phoenix
» Forum or FaceBook page?
» 75 Laguna project SOLD SOLD SOLD
» Someone save these..
