PWR steering pulley leak
Is it possible to repair power steering leak from it's axle i think?
Or only replacement will save me?
Thank you
Thank you
builtnotbought- G3GM Member
Re: PWR steering pulley leak
I think you would probably be better off buying a remanufactured pump. They are pretty cheap.
May be, but it's time.
Took of pulley, it's leaking from the axle
So, I bought new gm seal for the axle.
Disassembled pump to pieces using this link http://www.corvette-restoration.com/restoration/motor_and_transmission/060813_power_steering_pump_rebuild.htm
Changed seal, assembled everything back together and... surprize, there is no leak now but pump doesn't work at all.
On lift when engine is off steering wheel is much lighter to turn than with engine on.
Question. Are there any tricks to fill dry pump and all system to prevent air inside and to make it work as usual?
I turned wheel several times from lock to lock adding fluid to level. Didn't help.
Or I need to disassemble it again and look for mistake?
Thank you
Found info that pressure valve can stuck in place if bleeding wrong way, need to check it.
Thank you
I've overhauled a few over the years with success. Get the front wheels off the ground, Turn wheel lock to lock with engine off. Add fluid as needed. This gets the air out. Don't fill to the top or it will push out the cap and make a nice mess. Did you tear it all the way down to the pump vanes/blades? Maybe one fell out? There's really not much to it. It should work.
73ss- G3GM Enthusiast
Thank you73ss wrote:I've overhauled a few over the years with success. Get the front wheels off the ground, Turn wheel lock to lock with engine off. Add fluid as needed. This gets the air out. Don't fill to the top or it will push out the cap and make a nice mess. Did you tear it all the way down to the pump vanes/blades? Maybe one fell out? There's really not much to it. It should work.
I will try again to get the air out.
Yes all the way down to blades, and i put it back the right side with rounded edges. Need to check but there were no extra parts after overhaul
It was wrong placed spring in the pressure valve. First inside goes the spring, than valve with mesh and then cap with thread. It's designed that way that spring succesfully goes between valve and cap = no pressure in the system. My fault.
» Power Steering Pump Pulley Half Moon
» Big Block Chevrolet Bracket and Pulley Locations
» leak at dipstick
» leak at dipstick
