Bumper thread?
Bumper thread?
I can't find it.
I thought we had at least one pretty good thread around here that addressed the bumper interchangeability throughout years, but I'll be darned if I can find it.
Question on the Chevelles:
I know that the 73 front and back bumpers are different from the 74-77 in every way. BUT I keep looking at pics and it looks like the 74/75 front and REAR bumpers will swap over to the 76/77 (even though they are a little smaller) without a ton of mods....right?
And the 75/76/77 taillight panels etc will all swap without changing the trunk and corner pieces...right?
Re: Bumper thread?
Here's a thread I started with some info
https://www.g3gm.com/t9463-76-77-malibu-back-side
The '74/75 bumper will fit on a '77 but the bumper fillers will need to be modified to work. The top lip on the 77 bumper is a lot longer than the 74/75 bumper and the bumper fillers need to be extended to cover the bumper struts. To use the rear tail lights from a 74/75 on a 77 you will need to weld in the tail panel. The 75 trunk lid is slightly different from the 74/75 as well. You also will need to use the corner or quarter panel extensions from the 74/75 to make the tail panel work too.
I have a '74 bumper on my '77 and will show pics of everything once the car is painted.
Hawk03- G3GM Enthusiast
Re: Bumper thread?
75 can be used Bobby on the 77 there is just a small different in the lip of Trunk lid and Tail light ext's But the Tail Panel it self will allow you to Choose between the 75, 76 , 77 Tails If you want the 74 Tails Like Hawk said you have to Change the Tail panel section to a 74 As the Holes are different for the Tailights
Re: Bumper thread?
My plan is to use a 74/75 rear bumper on my 77 and then drill out the shocks anyway, so the filler shouldn't be an issue...correct?
Now all I have to do is find the bumper.
No real plan to change the tail lights, but I couldn't remember the details. I am thinking about switching to 75s, but I like the 77s just fine too.
The Malibu has been on the back burner while I've tinkered with the other car.
I miss it.
So it's time to get back on it.
My problem is that I like every year 73-77 and I hard time trying to decide which parts of each I like the best.
I'm working on the wheels and the suspension next, then I'll tackle the body stuff.
I've been staring at that Laguna nose again. Dammit.
I miss it.
Re: Bumper thread?
Let me help with the Laguna nose dream. They all crack and make your paint effed up. Your welcome.
Re: Bumper thread?
If I weaken and put it on and that happens, then I'll put the 74 stuff back on. Or the 77. Or the 75.
Dammit. See?
Dammit. See?
Re: Bumper thread?
I can't help you if you are just going to talk yourself into a situation.
» Source for rear bumper filler panel & rubber bumper pieces.
» The interchangability thread
» show us your car thread ?
