complete shifter assembly
G3GM :: Classifieds :: Wanted
In search of complete shifter assembly. The two parts that go to the tranny the u-shape bracket that allows you to shift gears and the back mounting bracket that holds the shifter cable and "L" shape bracket that bolts to the shifter and bolts to the floor.
Can anyone help ?
Can anyone help ?
Vinni406- G3GM Newbie
Re: complete shifter assembly
I've got the "L" bracket...although, chances are that it would come with a shifter A$$'y if someone has one. I might even be able to scare up a shifter for you. Not sure if I have the (2) pcs that attach to the tranny. Will have to look thru my stash of parts.
If it's for manual transmission Hurst makes this stuff but it doesn't have the big l bra let might be worth a look on Craigslist for an old three speed set up
McCauley5983- G3GM Enthusiast
Mcarlo77 wrote:I've got the "L" bracket...although, chances are that it would come with a shifter A$$'y if someone has one. I might even be able to scare up a shifter for you. Not sure if I have the (2) pcs that attach to the tranny. Will have to look thru my stash of parts.
that would be awsome if you can find the complete shifter.the one thats on ebay is incomplete so let me know if you have it and would like to sell it. trying to convert my 73 from bench and column shift over to buckets and console. i have eveything else but shifter and parts
McCauley5983 wrote:If it's for manual transmission Hurst makes this stuff but it doesn't have the big l bra let might be worth a look on Craigslist for an old three speed set up
its for an automatic car
In case you dont care for originality and just want the floor shift. I wanted mine converted to but couldent find the right Stock 73 parts. So i modified the 72 horseshoe shifter and centerconsole to fit my 73. It looks Stock and works just fine. The l bracket i just flipped upside Down on the tranny, and i bought a complete console and shifter from a 72 ss. Its the same shifter as in Monte Carlo and more. So its easier to get hold of. Opgi has complete set and parts of both the shifter and console. Just for info.
Of course If you are all about original it wont work, but for a guy like me i can say it looks Real cool. Took a bit of work and time but was worth it.
Hs1973- G3GM Enthusiast
ebay has them all day long. even the bolt to hold cable end to bracket
1973montec- Donating Member
Montec is probably right. Pick up pcs here and there to complete the setup. Unfortunately, I don't have any of them right now.
don't show chris,he might buy it first.....lol haha I would think the pan bracket would be the same
http://www.ebay.com/itm/PONTIAC-FIREBIRD-FORMULA-TRANS-AM-TH350-automatic-shifter-cable-brackets-/201696007002?hash=item2ef604d35a:g:8bYAAOSwal5YCSkB&vxp=mtr
» 73-77 Hurst competition shifter assembly - does anyone have the correct Hurst aftermarket part numbers?
» Shifter Boot and Shifter likes factory
» 1973 Assembly Manual
