Turbo or supercharger?
Turbo or supercharger? Empty Turbo or supercharger?
Post by JB2wheeler on Sun Jul 24, 2016 9:46 pm
My big block has 10.5 to 1 compression ratio. Will the compression have to be reduced to install a turbo? How about with a supercharger? The engine vibrates quite badly when driving. I wonder if the engine could be rebalanced to reduce the vibration? JB
Street Cred : 28
Turbo or supercharger? Empty Re: Turbo or supercharger?
Post by bracketchev1221 on Mon Jul 25, 2016 6:20 am
Can you post more of the combination? I think 10.5 is too high to just bolt on a supercharging device. It can be done with some effort. But as far as vibrating, engines should be smoother the higher the rpm. If the vibration increases there is probably an issue.
Post by JB2wheeler on Mon Jul 25, 2016 10:23 am
When the car is driven at 60 MPH, because of the 3.42 gears it roars at 3,000 RPM and runs smoothly. I wish I had cast iron manifolds instead of tube headers. I no longer drive, glaucoma hit me hard. My kids drive the car in traffic mostly. I do not know if the engine is internally or externally balanced. If I went to lower compression I would have to get new pistons. JB
Street Cred : 28
Post by bracketchev1221 on Mon Jul 25, 2016 10:50 am
Well I am going to guess its a 454. And it is highly important to know if the engine was internally or externally balanced, and if the right balancer and flexplate/flywheel were used.
