1973 Laguna water pump...
Post by Daves'77 BU on Sun Jul 31, 2016 8:45 pm
Hello all...am changing my water pump. I cant get the power steering bracket bolt out, what am I doing wrong? does the steering bracket need to come off of the bottom of the pump...feeling stupid...Thanks...Dave
Daves'77 BU
Re: 1973 Laguna water pump...
Post by dynchel on Mon Aug 01, 2016 7:28 am
If its the same as a '74, the bracket straddles the water pump & has a captured nut on the side closest to the engine.  The bolt could be seized on the pump or the captured nut I suppose.  What's wrong? It won't loosen, or won't walk out?
Last edited by dynchel on Mon Aug 01, 2016 7:30 am; edited 1 time in total (Reason for editing : spelling)
Post by Daves'77 BU on Mon Aug 01, 2016 9:41 am
Hi...I cant get it to walk out, just spins...it is mostly out, i will try to cut it where the bracket meets the pump housing, there are two washers there...
Daves'77 BU
