Alternator upgrade
G3GM :: G3 Tech :: Electrical
Page 1 of 1 • Share •
Alternator upgrade
I wonder if there is any alternator that is used on modern (90-2000) US cars that can be fitted to old sbc block brackets and wiring?
My stock alternator on idle when 2 air compressors are running goes down from 14v to 12v according to gauge.
May be somebody had any experience in upgrading stock alternator to more powerful unit.
What output does stock alternator have (in Amps)? I don't have any marks on mine. Modern cars have from about 140A.
Thank you
Thank you
builtnotbought- G3GM Member
Re: Alternator upgrade
Loads of upgrades for our altenators. Its done all the time. Just google "chevy alternator si wiring harness". Plenty info out there.
- Street Cred : 71
For now I found that 10/12si can easily be upgraded to cs-144 140A alt
and found theeese
http://www.dbelectrical.com/p-4516-high-output-chevy-3-wire-alternator-140-amp-65-85.aspx
Looks like 10si body with 140A output.
and found theeese
If I were going to get a 140 amp alternator, I would at least get it based on the 12si because of the better cooling fan.
bigredlaguna wrote:If I were going to get a 140 amp alternator, I would at least get it based on the 12si because of the better cooling fan.
https://www.summitracing.com/int/parts/pwm-57294
10si body, 150A output on top and baffle like on 12si plastic fan
I have a 105 amp alternator speced for a iroc z. (Sorry don't remember exact year) but the case is the sane. It fits when used as a one wire.
I too had one off of a Camaro dynchel on my V-8 S10. If memory serves me correctly it was off of an 86. Worked great and I'll probably use one on my Chevelle too.
builtnotbought wrote:https://www.summitracing.com/int/parts/pwm-57294
This is actually a 12si case with a metal fan instead of the plastic one. This would be more reliable than the other one you picked because the case itself is designed to flow more air through the internal parts to prevent overheating.
Here is a good read about the differences.
http://www.madelectrical.com/electricaltech/delcoremy.shtml
bigredlaguna wrote:builtnotbought wrote:https://www.summitracing.com/int/parts/pwm-57294
Thank you! I will read it!
Great read bigredlaguna. Thanks for sharing it.
» Weber alternator problems
» Fox Shocks Rebuild/Upgrade
» Adding a Mitsubishi 3 wire alternator
» Arctic Cat 700 Clutch Upgrade Suggestions
» JR PCM9 Transmitter
» 700r4 trans problem?
» 73 CHEVELLE ,Austin
» New Member 1975 Laguna s-3
» New guy!
» 75 Laguna , rough...but all there ?
» The ROTW Rocks
» 75 Gmc Sprint Sp from Quebec
