Under hood support rods
G3GM :: G3 Tech :: Body
Page 1 of 2 1, 2  Next
Post by Joe73 on Thu Sep 15, 2016 12:20 pm
Guys, the support rods under the hood, where they meet the fenders, is that supposed to be a stud that it goes onto? A stud that is fully threaded with a nut in the center so you can tighten it up? Then the rod goes on the top part of the stud and a nut secures it down ?
I have my blasted and epoxied rods out of storage and those studs and nuts arent with them. I just want to double check before I go crazy looking for them.
Anyone have a pair in case I dont find mine soon? I dont want this to delay my painting the body.
Thanks guys.
Street Cred : 71
Re: Under hood support rods
Post by Mcarlo77 on Thu Sep 15, 2016 1:10 pm
Nope...simply attached to the fender with a fender bolt.
Street Cred : 67
Post by Limey SE on Thu Sep 15, 2016 1:10 pm
No the welded Nut Goes Oh crap let me just take a Pic BRB
Street Cred : 90
Post by Hs1973 on Thu Sep 15, 2016 2:06 pm
Mine just attached to the fenders with the bolt that holds the fender. Not a specifik bolt or stud just a normal fender bolt. At the firewall is also no specifik bolt. Just a fenderbolt with a nut and washer. The fender brace goes under the little lip on the firewall, not on top.
Post by Limey SE on Thu Sep 15, 2016 2:12 pm
Second Pic Joe There IS A WELDED nut on bottom That goes to fire wall side other well it explains it self LOL
Street Cred : 90
Post by Joe73 on Thu Sep 15, 2016 2:14 pm
The support rod has.a.nut weled on one end and that's the.firewall end. I'm sure mine had , as well as.other 73s I've had, have a stud there and a flanges nut on top. The rod is slotted on the fender end.
Street Cred : 71
Post by clanceman427 on Thu Sep 15, 2016 2:30 pm
There is a good picture in the Gallery under 1973 Chevelles/Malubu of a survivor car, very good under hood reference pics. Itshows the stud and nut like Joe described. Now, don't know if that's a 1973-only thing or not.
Post by Limey SE on Thu Sep 15, 2016 2:49 pm
clanceman427 wrote:There is a good picture in the Gallery under 1973 Chevelles/Malubu of a survivor car, very good under hood reference pics.  Itshows the stud and nut like Joe described.  Now, don't know if that's a 1973-only thing or not.
  Yes this is a True Survivor Car 1973 posted by Member DineSS
[img][/img]
Street Cred : 90
Post by testpilot61 on Thu Sep 15, 2016 3:58 pm
I have a set of underhood braces if you don't fine yours.
testpilot61
Post by Joe73 on Thu Sep 15, 2016 4:18 pm
Thanks. I have the braces. But for.some reason the studs are.not with them. I blasted and epoxied them all together. Just misplaced the studs.
Street Cred : 71
Post by Mcarlo77 on Thu Sep 15, 2016 4:56 pm
Hmmm...if these cars had studs for the fender end to fit over, that's news to me. I've removed a number of these rods (including a set not long ago from a '73 Monte) and never found any like that.
Street Cred : 67
Post by Limey SE on Thu Sep 15, 2016 5:22 pm
The Only thing I know of is the Firewall side having a Nut welded to bottom of rod The you put bolt On from top of Firewall side and the Welded nut is what secures it to firewall on all I have seen anyway. Is it Possible when you Blasted it separated from the Rod Joe ?    I mean if it Happened its an Easy peasy fix just take screw from it to Lowes or Similar and match it up to a 4 sided nut and Tack it back on
Street Cred : 90
Post by Joe73 on Thu Sep 15, 2016 5:41 pm
My rods are perfect, the.nut is on both of them. I just ding know where.I put my studs after I blasted them.
Street Cred : 71
Post by 73ss on Thu Sep 15, 2016 5:44 pm
Studs here. I lost one and found a replacement at a independent parts store.
Street Cred : 10
Post by alowerlevel on Thu Sep 15, 2016 6:55 pm
Studs on my 73 as well
Best pic I could find that you can see one (on the driver side)
alowerlevel
Street Cred : 6
Post by Limey SE on Thu Sep 15, 2016 6:57 pm
73ss wrote:Studs here. I lost one and found a replacement at a independent parts store.
Ok you Studs LOL What are these mystery parts you speak of ?  Mine Has Bolts One for Firewall side one for Core support Side
Street Cred : 90
Post by Limey SE on Thu Sep 15, 2016 8:01 pm
73 Must be the Only Year and depending On plants they were Built at Every 73 I have had and / or parted out had the Biolt holding it not a stud HMMMMM
alowerlevel wrote:Studs on my 73 as well
Street Cred : 90
Post by Joe73 on Thu Sep 15, 2016 9:08 pm
Ok, consensus says, MOST 73's have a stud. Now I have to find mine. LOL
Street Cred : 71
Post by Limey SE on Thu Sep 15, 2016 9:52 pm
Joe73 wrote:Ok, consensus says, MOST 73's have a stud.  Now I have to find mine.  LOL
 Maybe if your Really really Nice Alower will measure what his is and Hardware Store Bound LOL
Street Cred : 90
Post by Joe73 on Fri Sep 16, 2016 12:36 pm
Ok, searched this morning and no luck.  Anyone have a pair of these studs to sell ?
I'm just going to use a fender bolt for now since the rods arent going in anytime soon.  Motor has to go in first.
Street Cred : 71
Post by pila on Sat Sep 17, 2016 1:07 am
I've had two Chevelles, a '73 and my current Malibu, & four Elcos of the G3 era, '73, '75, '76, and '77, and all had the same braces.
I have a spare pair here Joe. How about 25 bucks plus the shipping ? I have a mailing tube that will hold them.....
Bill
Post by Joe73 on Sat Sep 17, 2016 7:27 am
Bill, just looking for the studs and nuts. PM sent.
Street Cred : 71
Post by eboklund73 on Sun Sep 18, 2016 2:06 pm
Joe73,
I have a set of hood support studs and mounting hardware.
I sent you a PM
Thanks - Eric
eboklund73
Post by Joe73 on Sun Sep 18, 2016 4:17 pm
Eric, no PM came through.
Street Cred : 71
Post by Joe73 on Mon Sep 19, 2016 8:19 pm
Got a set of studs !! Thanks Eric !
Street Cred : 71
