Valve Cover Gaskets
Valve Cover Gaskets Empty Valve Cover Gaskets
Post by Mcarlo77 on Tue Oct 11, 2016 6:14 pm
I'm sure this has been discussed a time or two (lol!)...but, I was either not paying attention or memory is fading. What is the best valve cover gasket for stock SBC (350) engine? Like everything else you read online, everybody has their favorite. Cork? Rubber? Cork/Rubber? Fel-Pro Permadry? What thickness? Use RTV with your favorite? Help...I got a leaker, here!
Street Cred : 68
Valve Cover Gaskets Empty Re: Valve Cover Gaskets
Post by Joe73 on Tue Oct 11, 2016 6:20 pm
Ever since GM started using reusable tranny pan gaskets I've loved them. Easy off easy on. No glue or cements. And they have a rigid frame inside so they dont get out of shape and you cant overtighten.
Just like these. http://www.speedwaymotors.com/Speedway-Small-Block-Chevy-Steel-Core-Valve-Cover-Gaskets-Pre-1986,1872.html
Street Cred : 73
Post by dragons_lair59 on Tue Oct 11, 2016 10:41 pm
think its felpro that has the rubber gaskets. I've used them and loved the no leakes and if i needed too rebuild i could reuse. pluse the oil pan gaskets are one pc and i never had a leak from them. only thing is you need a longer v/c bolt if i remember right. ones for aluminum covers
Sam
Managment
Managment
