Cragar S/S lug torque
Cragar S/S lug torque Empty Cragar S/S lug torque
Post by KC77Monte on Sun Oct 30, 2016 4:16 pm
Finally got new wheels and tires mounted for the Monte Friday and need some advice on what to torque the lugs to. The wheels are Cragar S/S. Thanks
KC77Monte
KC77Monte
Cragar S/S lug torque Empty Re: Cragar S/S lug torque
Post by bracketchev1221 on Sun Oct 30, 2016 6:01 pm
I use 75 ft lbs.
Post by KC77Monte on Mon Oct 31, 2016 10:25 am
Poking around last night on the cragar site and noticed they say 70-80, the tire shop told me 100. So I split the difference and did 90. Hopefully that works. Thanks
KC77Monte
KC77Monte
Post by chevellelaguna on Mon Oct 31, 2016 12:56 pm
75-100 ft/lbs on steel wheels is usually sufficient. Aluminum wheels are usually around 100, also need re torqued after being driven. Seen cheap lug nut studs break at above 100 ft pounds. Make sure the threads are engaged completely in the lugnut. Some rims face are thicker than stock steel wheels and not enough threads are engaged within the nut, becomes a safety issue.
Street Cred : 16
Post by newmexguy on Wed Jan 11, 2017 10:52 am
Would use Cragars' recommendation.  Cannon lug nuts need to be periodically checked and retorqued.
newmexguy
