Sealed beam to composite conversion?
Sealed beam to composite conversion? Empty Sealed beam to composite conversion?
Post by 77dreammachine on Tue Nov 01, 2016 10:37 pm
Does such a thing exist for the good ol' 4 headlights on a 77'? I do like to 4 to 2 headlight conversion, but I'm looking to keep the quad headlights for originality sake but, I would really like to get better lighting performance for my headlights. Any suggestions?
77dreammachine
Sealed beam to composite conversion? Empty Re: Sealed beam to composite conversion?
Post by fasrnur on Tue Nov 01, 2016 11:05 pm
Post by pila on Wed Nov 02, 2016 12:41 am
I bought the Sylvania performance lamps for the El Camino, then I wired in two relays to run the quad headlamps. The lamps are very bright now, with the #12 wire replacing the tiny gauge stuff that the factory has been using for a long time. The light switch just just the relays...
Not sure if there are better lamps for the quad set up..
The next one is the wife's Jeep ! Those lights are really bad ! Exclamation
My '74 Malibu has the dual lights, but they don't seem any better than the quads..
Post by dynchel on Wed Nov 02, 2016 8:40 pm
Here's what I did.  $20.00 halogen truck drivinglights behind the grille.  No kidding, these are brighter than my headlights
Post by crice63 on Thu Nov 03, 2016 1:39 am
pila wrote:I bought the Sylvania performance lamps for the El Camino, then I wired in two relays to run the quad headlamps.  The lamps are very bright now, with the #12 wire replacing the tiny gauge stuff that the factory has been using for a long time. The light switch just just the relays...
Bill do you have pics/diagrams up somewhere on this?  Seems a simple enough improvement and it looks like I'm working on my front wiring now, might as well see if I can add this in.
Post by Tom77 on Wed Nov 23, 2016 3:35 pm
