Lakewood Bolt On Ladder Bars 1973-1977 A Bodies
Post by Jeff-45 on Sat Nov 26, 2016 11:03 am
Looking to sell the set of Lakewood Bolt On Ladder Bars that were on my 1974 Cutlass.
Lakewood no longer manufactures the bolt on ladder bars for 73-77 A bodies. They still manufacture the slapper bars.
They are bolt on no welding required. You will need to drill two holes in the frame to mount the front bracket. It also bolts to the front trailing arm bolt/nut/bushing.
I'm changing to adjustable upper and lower control arms.
I have pics that I can send to those interested.
They are black, powderocated with all of the mounting hardware etc.
Lakewood has the instructions for the 68-72 A Bodies, Same procedure for installation.
https://www.carid.com/lakewood/ladder-bars.html
Jeff-45
Re: Lakewood Bolt On Ladder Bars 1973-1977 A Bodies
Post by Joe73 on Sat Nov 26, 2016 12:08 pm
Unless they changed their design, the 73-77 should bolt to the lower shock bolt in the rear. Unlike 68-72 which bolt to the rear most lower control arm bolt. Directions should be.different.
Post up a pic.if.you can.
Street Cred : 71
Post by fasrnur on Sun Nov 27, 2016 5:40 pm
If I wasn't going a different direction, I'd be interested in them. I've always loved the way they look and how well they performed. Back in the day, the early to mid 70's, these were the way to go for anyone that had a coil spring GM car. How much you asking for them Jeff?
Street Cred : 6
Post by 1973 454 MONTE on Mon Nov 28, 2016 8:17 am
I had these on the monte for 10 years. replaced the lower bar,and you could not use a sway bar.
Street Cred : 35
Post by Joe73 on Mon Nov 28, 2016 8:23 am
Those replaced the.lower.control arm? That's.pretty cool. Never.seen those.before. They look like a ladder.bar.
Street Cred : 71
Post by Jeff-45 on Mon Nov 28, 2016 6:15 pm
The lower control arms are still used. Makes the car stiffer and hooks better.
Jeff-45
Post by Jeff-45 on Mon Nov 28, 2016 6:18 pm
I'm asking $250. Also posted locally on Detroit craigslist.
http://detroit.craigslist.org/okl/pts/5892928586.html
Regards,
Jeff
Jeff-45
Post by Jeff-45 on Mon Nov 28, 2016 6:34 pm
Image of the ladder bars
Jeff-45
Post by Jeff-45 on Mon Nov 28, 2016 6:38 pm
I haven't figured out how to imbed a pic. I keep receiving a Syntax error?
Here's a link of my '74 Cutlass.
Jeff-45
Post by Limey SE on Mon Nov 28, 2016 9:09 pm
LIMEY LIKES THIS RIDE VERY NICE
Street Cred : 90
Post by Joe73 on Mon Nov 28, 2016 9:43 pm
Limey SE wrote:LIMEY LIKES THIS RIDE VERY NICE
Me too, Me too. What size back tires were those ??
Street Cred : 71
Post by Jeff-45 on Mon Nov 28, 2016 10:19 pm
325/50/15. Had to roll the wheel well lip a little. Pained me to do, but upgrading from the 350 olds to the 455 (.060 over), I needed more traction.
The Chevelle's look good. My Dad had a 75 Malibu, picked up from a little old lady with 10K on the odometer.
Jeff-45
Post by Chris45 on Sun Feb 05, 2017 12:12 am
I was wondering if you still have the ladder bars off the 74 cutlass if you do are you still willing to sell them
Chris
Chris45
