complete shifter assembly
complete shifter assembly Empty complete shifter assembly
Post by Vinni406 on Mon Nov 28, 2016 10:34 pm
In search of complete shifter assembly. The two parts that go to the tranny the u-shape bracket that allows you to shift gears and the back mounting bracket that holds the shifter cable and "L" shape bracket that bolts to the shifter and bolts to the floor.
Can anyone help ?
Vinni406
complete shifter assembly Empty Re: complete shifter assembly
Post by Mcarlo77 on Tue Nov 29, 2016 1:06 am
I've got the "L" bracket...although, chances are that it would come with a shifter A$$'y if someone has one. I might even be able to scare up a shifter for you. Not sure if I have the (2) pcs that attach to the tranny. Will have to look thru my stash of parts.
Street Cred : 68
Post by McCauley5983 on Tue Nov 29, 2016 10:01 am
If it's for manual transmission Hurst makes this stuff but it doesn't have the big l bra let might be worth a look on Craigslist for an old three speed set up
Street Cred : 14
Post by Vinni406 on Tue Nov 29, 2016 10:29 am
Mcarlo77 wrote:I've got the "L" bracket...although, chances are that it would come with a shifter A$$'y if someone has one.  I might even be able to scare up a shifter for you.  Not sure if I have the (2) pcs that attach to the tranny.  Will have to look thru my stash of parts.
that would be awsome if you can find the complete shifter.the one thats on ebay is incomplete so let me know if you have it and would like to sell it. trying to convert my 73 from bench and column shift over to buckets and console. i have eveything else but shifter and parts
Vinni406
Post by Vinni406 on Tue Nov 29, 2016 10:31 am
McCauley5983 wrote:If it's for manual transmission Hurst makes this stuff but it doesn't have the big l bra let might be worth a look on Craigslist for an old three speed set up
its for an automatic car
Vinni406
Post by Hs1973 on Wed Nov 30, 2016 1:51 pm
In case you dont care for originality and just want the floor shift. I wanted mine converted to but couldent find the right Stock 73 parts. So i modified the 72 horseshoe shifter and centerconsole to fit my 73. It looks Stock and works just fine. The l bracket i just flipped upside Down on the tranny, and i bought a complete console and shifter from a 72 ss. Its the same shifter as in Monte Carlo and more. So its easier to get hold of. Opgi has complete set and parts of both the shifter and console. Just for info.
Of course If you are all about original it wont work, but for a guy like me i can say it looks Real cool. Took a bit of work and time but was worth it.
Street Cred : 12
Post by 1973montec on Wed Nov 30, 2016 8:44 pm
ebay has them all day long. even the bolt to hold cable end to bracket
Post by Mcarlo77 on Wed Nov 30, 2016 11:58 pm
Montec is probably right. Pick up pcs here and there to complete the setup. Unfortunately, I don't have any of them right now.
Street Cred : 68
Post by 1973montec on Fri Dec 02, 2016 5:03 pm
