4-speed hole
4-speed hole Empty 4-speed hole
Post by JF74chevelle on Wed Dec 21, 2016 2:08 pm
Hey guys my last two parts for the trans swap are on their way the clutch rod firewall boot and a pilot pushing. Now i have a bench seat in my chevelle and i want to know if the hurst shifter will clear it and not interfere. And when i cut the hole for the shifter does it need to be directly in the middle of the hump or does it have to be to the left slightly? Thanks-Justin
JF74chevelle
JF74chevelle
4-speed hole Empty Re: 4-speed hole
Post by Joe73 on Wed Dec 21, 2016 2:21 pm
couple things.
Did you get the 70-81 camaro firewall boot?
Put a magnet to the pilot bushing, if it sticks toss it out and.get a bronze one.
Yes the shifter is offset to the drivers side.  Did you buy a 4 speed.hump for the floor?   Or are you just going to screw the.boot down.
Hurst handles are interchangeable.  Go to their site and find out which one you need.  I don't think they mention bench seat.  Only console.or.no console.
Street Cred : 73
Post by clanceman427 on Wed Dec 21, 2016 4:19 pm
Use PB-656-HD from advance auto. I just replaced my pilot bushing a year ago and searched high and low for the non magnetic version.. Like Joe says, when you get it give it the magnet test just to be sure.
4-speed hole Imag1010
Post by Joe73 on Wed Dec 21, 2016 4:43 pm
My Muncie.rebuild kit from jodys transmissions came with a non magnetic one. Great guy to deal with.
Street Cred : 73
Post by Joe73 on Thu Dec 22, 2016 2:14 pm
Also,.if.you go without the floor.hump you can get a "super boot" that will cover everything. Just search hurst super boot on eBay. They work well.
Street Cred : 73
