Polishing Grille
G3GM :: G3 Tech :: Body
Polishing Grille
Post by Hawk03 on Thu Dec 22, 2016 10:49 pm
Is there a good dremel or drill attachment that will polish the individual squares in '74 Chevelle grille? I used some jewelry polishing pads but they weren't able to get in the corners and the pads didn't last. I need something that will get in the corners of each square.
Street Cred : 13
Re: Polishing Grille
Post by Mcarlo77 on Fri Dec 23, 2016 12:46 am
That's an ambitious undertaking, Robert! What are there...something like 792 squares? I live by the Dremel (burned up several over the years)...but, can't think of a polishing bit that would get into the corners because they are obviously all circular in design.
Street Cred : 67
Post by Hawk03 on Fri Dec 23, 2016 8:58 am
Haha I know! I figured I'd try an attachment before I had to do it by hand.... pale
Street Cred : 13
Post by Mcarlo77 on Fri Dec 23, 2016 10:20 am
These are long, tapered felts bits might get you into the corners. Worth a shot. You'll probably go through a bunch if they should work, however. Good luck!
http://www.ebay.com/itm/10x-Long-Pointed-Bits-Felt-Wool-Polishing-for-Dremel-Rotary-Tool-1-8-shank-/142221195389?hash=item211d0b387d:g:iJ0AAOSwgQ9V27z~
Street Cred : 67
