Brake line questions
Post by bitterfitter on Sat Dec 31, 2016 12:17 pm
So while changing my front springs the caliper fell pulling on the brake line and broke it. Since I have to replace the line I thought maybe I'd do them all. Should I go stainless? Is it worth it on a limit use car that sits in a heated garage when not in use. Also I have a Wilwood adjustable proportional valve. I bought it when I bought my disc brake rear end. I haven't installed the rear end yet but I still may. Should I toss the original valve and use this one? Thoughts?
bitterfitter
Re: Brake line questions
Post by Joe73 on Sat Dec 31, 2016 2:19 pm
Valve is up to you. I went regular steel lines. Anytime you have two dissimilar metals you get cross corrosion. And the steel ones lasted more than 40 years
Street Cred : 70
Post by bitterfitter on Sat Dec 31, 2016 3:10 pm
Good point on the corrosion. I hate bending stainless vs mils steel anyways.
I would like to do the valve in case I ever put the other disc brakes on the back.
Any idea if the lines are all one size? Say 3/16" maybe.
bitterfitter
Post by Joe73 on Sat Dec 31, 2016 3:16 pm
I don't recall. But I bought mine from in linetube.com. Check their site.
Street Cred : 70
Post by pila on Sat Dec 31, 2016 11:57 pm
Joe, I think that is inlintube.com They have pre-bent lines ,hoses etc, and located in the Detroit area.
I used steel lines, and painted them, before & after installing them, except the lines running up the the MC, which are stainless, that they sent by mistake !! Very Happy
Post by Joe73 on Sat Dec 31, 2016 11:59 pm
Your right Bill. I was typing on my phone and it wouldnt put all the letters together for some reason. LOL.
HAPPY NEW YEAR !!!!
Street Cred : 70
Post by dynchel on Sun Jan 01, 2017 5:27 pm
Since replacing brake lines is part of my job I'm used to making my own. There is a nice ez bend line that is copper I believe, very easy to work with and won't rust. Should be available at Napa stores
Post by bitterfitter on Fri Jan 06, 2017 11:04 am
Thanks for the heads up about the brake line materials. I will check that out.
bitterfitter
Post by bitterfitter on Fri Jan 06, 2017 11:08 am
So while I am working on the brakes, I figured I may just replace all the worn out parts on my ride.  I have new rotors, rubber hoses, pads for the front.  The rears have already been done from brake cylinder to hardware and shoes.
I have replaced my master cylinder already,but now would like to replace my booster and possibly the proportioning valve with new ones.  Any suggestions where to find these and anything to watch out for?  It appears there are a few different shape, size boosters out there.  Would like to find one like the original.  Same with the proportioning valve.
bitterfitter
Post by Hawk03 on Fri Jan 06, 2017 12:02 pm
I purchased my valve from Inline tube and everything was correct. Info is in this thread.
http://www.g3gm.com/t7561-proportioning-valve-questions
Not sure about brake booster.
Street Cred : 12
Post by Joe73 on Fri Jan 06, 2017 12:21 pm
With the proportioning valve, keep an eye on the way the brake wire hooks up. Thats where the differences usually are. Ours is a stud.
Street Cred : 70
Post by brownbomber77 on Tue Jan 02, 2018 2:53 pm
How did the Inline tube stuff line up? Was it pretty plug and play as far as fitment?
brownbomber77
Street Cred : 4
Post by bitterfitter on Tue Jan 02, 2018 3:20 pm
All the lines I have bought from them go on like factory pieces. I used to work at a Corvette shop here and we got all our stuff from them. I would usually go down there and pick it up. Very nice setup they have. I have been through the place and seen the machines in action a few times. Amazing....
bitterfitter
