Armrest brackets 1973 Chevelle 2 door
Post by BigSythe on Sat Jan 07, 2017 11:35 am
Looking for set of armrest brackets for 1973 Chevelle.
BigSythe
BigSythe
Re: Armrest brackets 1973 Chevelle 2 door
Post by 1973montec on Sat Jan 07, 2017 2:08 pm
you want the metal piece that bolts to door so lower panel can bolt to it
Post by BigSythe on Sat Jan 07, 2017 7:13 pm
Yes, mine were lost in the flood here in Baton Rouge in Aug.
BigSythe
BigSythe
Post by 1973 454 MONTE on Mon Jan 09, 2017 3:47 pm
I should have a set. give me a chance to look. its kinda chilly up here in ohio
Street Cred : 35
Post by pila on Mon Jan 09, 2017 6:08 pm
If you can't find them, I have a pair..
Post by BigSythe on Tue Jan 17, 2017 4:57 pm
Thanks fellas, have a pair on the way!
BigSythe
BigSythe
Post by Hawk03 on Sat Jul 01, 2017 12:20 pm
Is there a difference between the arm rest bracket and the year of the car/door? I think my doors are off of a '74/'75 Chevelle and my brackets are from my original doors which was a '77 and they won't fit on my current doors. The bottom tabs will fit in the slots but the screw holes are way off and are higher on the door than on the bracket.
Street Cred : 13
Post by Hawk03 on Mon Aug 28, 2017 9:18 am
Hawk03 wrote:Is there a difference between the arm rest bracket and the year of the car/door? I think my doors are off of a '74/'75 Chevelle and my brackets are from my original doors which was a '77 and they won't fit on my current doors. The bottom tabs will fit in the slots but the screw holes are way off and are higher on the door than on the bracket.
Here is a picture of my arm rest brackets on the door. I inserted the tabs into the holes but the screw holes do not line up. The tabs are all the way in and if I move the bracket to line up with the screw holes, the tabs will come out of the holes. Are there different brackets I need?
Street Cred : 13
Post by Mcarlo77 on Mon Aug 28, 2017 7:26 pm
Don't have an answer to your question as I thought that they would all be the same since the lower door panels/armrests are in the same location. I measured the width (top to bottom) of one I just took off a spare '74 Chevelle door I have and it measures 9 3/4" dead nuts from top edge to bottom of tab when set on the ground. And no offense, but I'm not going to remove the door panel on my '77 Monte to confirm. I'd just install the tabs and drill new holes at the top. Then, test fit your door panel/armrest.
Street Cred : 67
