She sings
Page 1 of 3 1, 2, 3  Next
She sings Empty She sings
Post by Damon23 on Sun Jan 08, 2017 3:05 pm
After going back and forth with this car I have decided it is time to see one thru. I've owned this car longer (10 months) than the last 5 so I guess that is a sign. My idea is something like Sean Rich's "Bad Buzz" or commonly known as the "Bank Robber Special". Except mine will stay sort of a cruiser with a little punch behind it. So, here we go. What I'm starting with.
She sings Pbucket
Woke up this morning to 16 degree temps and all three daily drivers were coated in ice. I spent a hour getting them unfrozen and warmed up the garage a little. I started to remove the trim in the drivers side. Most of it came off easy but it looks like I have to get the inner fender out to get the Malibu Classic Emblem and the lower rocker molding off. That will be another day. Good news is under that trim it is solid as a rock. Expected though out of a Texas/Nevada car. This is a major leap for me. I usually buy them how I want them and enjoy them and move on. But for some reason this car just fits me.
She sings Pbucket
She sings Pbucket
She sings Pbucket
She sings Pbucket
She sings Empty Re: She sings
Post by Hawk03 on Sun Jan 08, 2017 4:38 pm
I like it! Glad you are staying with it and making how you want it, which I think is the fun part about working on a project. I removed all of the trim and emblems and it looks a lot cleaner. Looking forward to you progress.
Street Cred : 13
Post by fasrnur on Sun Jan 08, 2017 5:48 pm
Onward and upward is what I always say Damon. Once you take that first screw or bolt off, you're on your way to what you want out of your car, and not what everyone else has or wants your car to be.
I applaud you for sticking with it and can't wait to see your progress.
Jeff.....
Post by knightfan26917 on Sun Jan 08, 2017 7:24 pm
Glad you are sticking with it, Damon!
"Don't get me wrong" | Billy Joel | 'My Life'
Post by pila on Sun Jan 08, 2017 8:54 pm
That appears to be a really nice car. Just what are your intentions ??
Bill
Post by Damon23 on Mon Jan 09, 2017 7:29 pm
pila wrote:That appears to be a really nice car.  Just what are your intentions ??
Bill
It is a decent car. I'm removing all the moldings and trim, removing the top and having everything fixed and resprayed. Going to swap out the wheels for either D holes or soft 8's. Having a nice sounding dual exhaust set up put on and slowly mod the motor. A LS would be nice but the car runs so well and has great vitals I think that is going to be far down the list.
Post by pila on Mon Jan 09, 2017 8:48 pm
Sounds like a nice plan ! That appears to be a quite nice car, like I said !! Very Happy
Post by Hs1973 on Tue Jan 10, 2017 1:02 pm
I wish i was Living a little closer to the us, cause all that trim you are taking off looks to be in good shape, and i would love to have it on my car. But Living in Europe makes the freight cost unbeliveble. And im not sure the parts would even survive the trip. Bummer but maybe it can make someone Else happy, i know it is hard to find espesially the wheel arch trim in usable condition. And the vinyltop trim is also a rare item nowadays. I could not find any when i restored my chevelle, so i modified a set from a 72 camaro, i heated it with a torch and changed its shape to fit and then i polished it. Alot of work.
She sings Empty Parts
Post by testpilot61 on Tue Jan 10, 2017 2:52 pm
Would you sell the lower moldings your taking off your car? Thanks, Jerry H.
testpilot61
She sings Empty Malibu Classic emblem
Post by testpilot61 on Tue Jan 10, 2017 2:59 pm
I was able to remove my emblem by slowly prying with a small flat screwdriver at the corner first then in the middle. Mine had barrel clips so it made removal much easier. JerryH
testpilot61
Post by Damon23 on Tue Jan 10, 2017 5:35 pm
testpilot61 wrote:Would you sell the lower moldings your taking off your car?  Thanks, Jerry H.
That is the plan.
Post by Damon23 on Tue Jan 10, 2017 5:36 pm
testpilot61 wrote:I was able to remove my emblem by slowly prying with a small flat screwdriver at the corner first then in the middle.  Mine had barrel clips so it made removal much easier.  JerryH
I wish I was so lucky. I can see one thru the door opening and they have speed nuts on them.
She sings Empty Lower moldings
Post by testpilot61 on Tue Jan 10, 2017 6:06 pm
I would consider purchasing the lower moldings. JerryHarman
testpilot61
Post by Damon23 on Tue Jan 10, 2017 7:03 pm
I'll let you know once they are off.
Post by Limey SE on Tue Jan 10, 2017 10:35 pm
DAMON I SO NEED NEED SO NEED THAT DOOR EDGE MOULDING if you were able to save it
She sings 12527912
Street Cred : 90
Post by Hs1973 on Wed Jan 11, 2017 1:27 pm
It is not that hard to take the Inner fenders out, that makes it easy to acces the mouldings/ emblems on the back for removel. The Inner fenders only takes about 10 minutters to remove. The passenger side is a little harder because you need to remove the battery and tray, but other than that its pretty straight forward. On the plus side it also makes it easy to do work in the engine bay, and you can get to paint or clean the Inner fenders.
Post by Damon23 on Sat Jan 14, 2017 1:58 pm
A little more progress. That dang lower fender molding was a pain. The nut closest to the door was not easy to get to even after pulling the inner fender down. So far so good on the top. Surface rust with a pits here and there. Nothing soft or holes yet. Looks like I have to sand that glue crap off. Maybe I'll see if the shop down the road can sand it down and put it in epoxy for me. I don't know if I want to put the drip rail back on or not. Kind of like the smooth look. I wish there was a way to make the opera window gap look good cause that looks good without the trim as well.
Oh, the front spoiler came the other day. Spoilers by Randy hooked me up. Ordered it last week and delivered this week. Good quality on the part too. Full instructions and mounting kit. Very impressed.
She sings 55B15915-9101-460A-B34D-C08D1E818DD9_zpsvlhhgpup
She sings D10D31B8-FC66-4389-99D6-B60C16253975_zpsm88mcfvx
She sings C58E9F7A-914C-4F83-B5AD-AB723024A17F_zps1ggspxwk
She sings 8F355C7D-C26D-4B66-B774-39A1B1C74F88_zps25iywn7z
She sings 2CADD35E-136F-457E-86C0-ADE17C037A59_zpstqjrdp1q
She sings 796CB831-486A-4A11-8C3A-BFBA735268E6_zpsa4spzbmq
She sings 2E9518BF-C391-4674-9042-66C876CAFD2B_zps4qrkj4id
Post by ant7377 on Sat Jan 14, 2017 5:17 pm
You can't get the fender emblem off from under the hood,if you stick your arm Down there next to the master cylinder?
Street Cred : 35
Post by Joe73 on Sat Jan 14, 2017 5:22 pm
Mask that car off with cardboard and duct tape and have a Dustless Blasting company blast all that rust off. Then 2 coats of epoxy and your good to go.
Street Cred : 72
Post by fasrnur on Sat Jan 14, 2017 6:50 pm
Not sure if it'll work or not Damon, but you might try lacquer thinner on the glue. I believe it just might soften it enough to take it off even after all those years of being on it. Sorta like when you take an emblem off that has double back tape holding it on. At least that's what I do to take glue and sticky stuff off.
Looking good so far, and man did you take the plunge.   Thumbs up
Post by Hawk03 on Sat Jan 14, 2017 8:38 pm
Nice! Can't wait to see the spoiler installed, I've been thinking about getting one of those as well. I didn't reinstall my drip rails and think it looks good without.
Street Cred : 13
Post by Damon23 on Sat Jan 14, 2017 10:41 pm
I think I messed up and removed a piece on the A pillar I was not supposed to. It looks like it is there to give the vinyl something to lay flat on. It took some prying to get it off but I can straighten it and put it back on then it will have to be smoothed out to blend from the roof to that piece. Anyway, here are some other pics of today's work.
She sings 0B309E61-FB51-42E0-9199-B47B09FD0681_zps5th2yp37
She sings 3B3871FF-9B64-411E-B030-A66A5577AC67_zpsvhucajav
She sings C11D2BE1-3AD0-46F0-9175-804D22DB614F_zpsjvybr3ra
She sings 0BC247F6-8D68-40F2-B5D2-8B125E5C6690_zps9g0afznx
She sings 71050B43-FB90-4492-8E90-01DACC45D803_zpsht0gbpdq
This is the worst of the rust on the roof. Does not seem too bad but once it gets knocked down I expect pin holes here.
She sings 76FB1E55-6309-42E2-BD35-8DC41F9D5EFB_zps2mubhbyb
Only body rust on the car.
She sings C07FFB50-EB4F-4C4C-8CC9-F596754FFEBF_zpsodij7iud
Post by Damon23 on Sat Jan 14, 2017 10:45 pm
So looks like I'll need to have some holes filled, a couple small patches and then get all that gunk off the roof and smooth it out. Then to save up for the respray. Looking to get the wheels and exhaust done soon. I decided to go with the soft 8's and paint them. Not sure on the color yet. I found two places here in GA that widens wheels. I think I'll have them put 1.5in in them and I'll run the 315/35/17 out back and up front 285/40/17 on the standard 9 in wheels. I have the double hump crossmember so that will make exhaust easy. Still not sure on the rear spoiler yet and if I should take the hood ornament off.
Post by Damon23 on Sun Jan 22, 2017 9:51 pm
Hmmmm. I thought for sure it was the factory top I pulled off the car. Started stripping the roof and found filler/fiberglass in the top of the sail panel and where the roof meets the sail panel towards the rear. I'm pretty sure their is supposed to be lead in there. I'm still considering myself lucky. Got half the roof done when I got home.
Question. For non vinyl roof cars, what did they use in the A pillar? I had a metal piece that was on there that I removed. Check out the picture of what was underneath. And it was not a smooth transition from the roof to that piece. Would that have been leaded as well? I may need a new metal piece that runs down the A pillar cause I bent mine removing it.
She sings 25FD7286-518F-41AB-BBA8-FCF1B81A1200_zpsceughdji
She sings 42624965-309D-44F0-9B47-EDB4ED69FC10_zpsq5w23w6a
She sings 19E99CD3-B571-49AC-A347-748F1DB72FD2_zpstajudurg
She sings C42E9D44-5FFC-44E3-AEAB-CF98F3EAE473_zpshrixhjhz
She sings E64422FA-9C73-49BC-B6E9-EFF3A80ECFE0_zpst4ffaj5h
Here is what I'm talking about. It looks like their was some filler there as well. Oh well. I'm going to put some of this rust encapsulator on the pits from rust and then have to smooth it over with all metal. I guess I can make the transition here with the same.
She sings 51FF25E1-C4C7-4B33-BD13-884DD0885C5F_zpsd6oucdtp
She sings 2D04FBA2-52FA-48F1-9A12-754A21F83276_zpsuicnmpdk
Post by Damon23 on Sun Jan 29, 2017 4:17 pm
Got the front spoiler on today that I got from Randy. It is a very nice piece. Good clear instructions with the brackets and hardware. It had me scratching my head on why the center bracket would not line up. Duh!!!!!!!!!!!!!!!!!!!!!!!! Tucking the front bumper throws off the alignment of the bracket LOL. I have better bits at the shop so I'll grab one of those and drill a new hole in the spoiler and bracket tomorrow. Went on quick, remove the two lower inner bumper support bolts and install the brackets, remove the lower radiator support bolt and install bracket. Hand tighten back and loosely install hardware to spoiler and line everything up and tighten. I can see having to touch this thing up though but that is the least of my concerns. I highly recommend this piece.
She sings 2AC01FB0-79C1-420C-A5D8-1B2B3AAEDD45_zpsw8u0ms9t
She sings DBB96A8F-1EEB-484A-8845-71AEEA9DE8CF_zpsbomwkv8g
She sings 4A339008-9D1B-4A2D-84B8-F191DEA809AB_zps1x1v09sq
She sings D90DA616-2170-4095-8FCB-B8BCD929BC44_zps3eeo0yqp
She sings 1276FCDA-D197-4C9E-BBD0-44095ACA2365_zpso8blzzlp
