Power window electric connector wiring
Power window electric connector wiring Empty Power window electric connector wiring
Post by Trbulnc on Sun Jan 08, 2017 10:15 pm
So I have had a few since I removed the wiring and all window works on my chevelle. It is a power window/lock setup. Have it all back together but can't find the wiring connector for the drivers window motor. Connector or wiring. The pass side has the connector spliced into the window switch but not on the drivers side.
Anyone throw me a bone on this one? Lol.
Trbulnc
Power window electric connector wiring Empty Re: Power window electric connector wiring
Post by Mcarlo77 on Sun Jan 08, 2017 11:21 pm
So...are you missing the entire pigtail harness that runs from under the dash to the window motor and door switch? Or, did someone just snip the blue and brown wire that runs to the motor?
Street Cred : 68
Post by Trbulnc on Mon Jan 09, 2017 9:32 am
I think I could be missing the harness? If so, I don't see where it should route from under the dash. I thought I kept all the wires together when I disassembled but I evidently didn't. The pass side is spliced into window switch wiring.
Trbulnc
Post by Mcarlo77 on Mon Jan 09, 2017 3:03 pm
What you should have is a five-part wiring harness. You'll have the crossover harness that runs from side to side under the dash. There are two plugs on each end of that...one for the pwr window pigtail and one for the pwr lock pigtail in each door. Those door pigtails join the crossover harness under the dash and in the general area above each kick panel. I may be able to help once you determine exactly what you need.
Street Cred : 68
Post by Trbulnc on Mon Jan 09, 2017 3:24 pm
I'll take a picture of what I have and post it later tonight. I'll look again to see if that motor connector is tucked under the dash somewhere I can't see. Painter might have hidden it.
Trbulnc
Post by bitterfitter on Mon Jan 09, 2017 3:27 pm
Just as he said above.  It sounds like you are missing the door wiring that connects under the dash and runs out through the door jamb boot to the door switchs and such.  This connector is just inside the car under the dash right about at the oval hole where the door jamb boot connects to the car body.  I think mine has black and slightly rectangular, female end.  I believe it is nearly indentical to the passenger side setup, so if you are good on that side, look up under the dash for that connector in the same area but on the passenger side.
bitterfitter
