1986 chevelle or malibu lower trailing arms wanted
G3GM :: Classifieds :: Wanted
Hi I'm looking for a set of trailing arms for gm 10 bolt for the sway bar attachment
76 GMC sprint- G3GM Newbie
Re: 1986 chevelle or malibu lower trailing arms wanted
1973 to 77 sorry I don't know how the year was wrong
Just buy the inserts and drill yours. Very easy. And cheap.
Ours inserts are the same as the later years Caprice. Only difference is that ours uses standard thread and the Caprice inserts are metric thread.
Limey should have the part number handy.
I have new inserts already I wasn't sure if I could just do that thx for your help
Absolutely. And if you dont want to remove the arms from the car, put a jack under the lower shock mount, take out your lower shock bolt, and lower the rear and you should have enough access to drill the holes.
Oh ok I want to change my original air shocks and put on my new nos ones I bought last year at a swap meet
I weld a piece of steel to the bottom and drill through the top, and weld in sleeves top to bottom
brownbomber77- G3GM Member
Hi thanks for your input that sounds like a good idea
» Wanted: 73-77 Chevelle/Malibu Rectangular Speedometer Gauge Cluster
» WANTED: 76-77 Chevelle/EC AM/FM MONO RADIO
» wanted: 74, 75 malibu classic interior quarter window sail panels
