76 trim code
76 trim code
Can anyone decode this for me? I know what most of it means but I'm unsure of the codes 08N, AN7, 03B. Any help would be appreciated
thert1976- G3GM Newbie
Re: 76 trim code
Can you post the codes as they are stamped on the tag ? I know AN7 would be in the second line.
Or better yet, post the entire trim tag line by line. That way we could decifer which are the build date, trim colors, paint codes, etc.
AN7 means swivel buckets for our cars. A52 would be a bench. And I think there was a A65 which was a split bench with armrest. If I remember correctly.
Re: 76 trim code
I have tried to post a pic of the tag but can't get it to go through.
Re: 76 trim code
thert1976 wrote:I have tried to post a pic of the tag but can't get it to go through.
text to 815-269-6798 will post it up for you
Re: 76 trim code
08N is Dark Mahogony
03B is March (03) 2nd week (B) Build Date
AN7 is Swivel Buckets as Joe stated
Decode
I have an 09E for the build date.
Is this Sept 5th week?
testpilot61- Donating Member
Decode
Thanks. I have my original build sheet. It shows many options that I haven't seen on other Malibus. One particular code is damaged on the build sheet with a hole. I can make out ?C8 Demo Drive Pk. May be a VC8.
Any help with this one????
Thanks, Jerry
Thanks, Jerry
Re: 76 trim code
I got nothing on that code or description in my RPO code list. Can't even imagine what that would refer to.
What are some others?
Build codes
AU3. A31, A42, A65, BY1, B84, B93, B96, CB4, CD4, C50, C60, D24, D34, K30, N33, UF3, UF7, U25, VE5,V30, VC8, ZJ9, ZO3, ZJ9, N41, K30
I hope I can learn what the "Demo Drive Pkg" included. (VC8 maybe ZC8) thats the one with the whole in part of the number.
Anyhow, these are most of the Build sheet items. Car was built in Arlington, Tx
Thanks, Jerry
Thanks, Jerry
Today at 1:25 am by 77camino
Tue Mar 26, 2024 10:35 pm by Whisperer
Tue Mar 26, 2024 5:33 pm by Finn Monte
Mon Mar 25, 2024 10:37 pm by Joe73
Mon Mar 25, 2024 3:39 am by g3chevy / Mr Pontiac
Fri Mar 22, 2024 10:21 pm by Joe73
Thu Mar 21, 2024 10:58 pm by Limey SE
Thu Mar 21, 2024 4:23 pm by Joe73
Wed Mar 20, 2024 9:33 pm by Limey SE
Wed Mar 20, 2024 5:26 pm by Limey SE
