73 SS Core Support Bushings
G3GM :: G3 Tech :: Body
Post by Jeff73SS on Thu Jan 26, 2017 11:58 am
I took my 73 SS apart a long time ago and am slowly getting it back together. My question is in the new core support bushings I purchased one rubber bushing has a metal (lets call it a stem) in it. I am assuming it supports the weight and goes between the frame and core support with the washer facing the frame and the rubber bushing should easily go through the support and protrude a bit (male) in order for the top portion of the bushing which goes on top the support (female) can comfortably fit together with it without one or the other being crushed more than the other? Also does the bottom bushing (male need to be pressed into the support as it does not want to stay in the hole unless under force.
Thanks,
Jeff
Jeff73SS
Re: 73 SS Core Support Bushings
Post by Joe73 on Thu Jan 26, 2017 1:26 pm
A bit rusty but you get the point.
Street Cred : 71
Post by Jeff73SS on Thu Jan 26, 2017 1:45 pm
Thanks Joe. Jeff
Jeff73SS
