Alternator tensioner
Alternator tensioner Empty Alternator tensioner
Post by Joe73 on Tue Feb 07, 2017 6:39 pm
Can anyone grab me a measurement ? I'm looking for the measurement from the alternator bolt that you tighten to keep your belt tight to the bolt on the water pump that the alternator bracket bolts to.
Reason being, I'm considering replacing the stock alternator bracket with an adjustable stainless tensioner with heim joints on the ends. I like the look of them instead of the flat stock bracket. I have a brand new chrome skinny aftermarket bracket that I like but I like the look of the stainless too. And I figure I'll put the negative battery cable down low into one of the threaded bosses by the fuel pump.
If a couple guys could post up the length between those two bolts, I'd appreciate it. Thanks
Street Cred : 75
Alternator tensioner Empty Re: Alternator tensioner
Post by Limey SE on Tue Feb 07, 2017 8:39 pm
If No One does By tomm at 4pm Joe I will grab it for you Too dark right now
Street Cred : 92
Post by Joe73 on Tue Feb 07, 2017 8:49 pm
Cool, thanks.
Street Cred : 75
