Rear sway bar
Rear sway bar
I bought a 9C1 rear sway bar for my 75 Malibu. I know I have to remove the trailing arms to drill for the bracket holes. Anyone have the measurements for the holes? Thanks.
Damon23- G3GM Member
Re: Rear sway bar
I will be out with Car this weekend here if no One else chimes in and get measurement's Damon will be 47 degrees and getting a Jump Start on Interior Removal for the New going in, WOOT WOOT Bite me Mother Nature and I am having your Groundhog on the grill As well B***H
Re: Rear sway bar
If you support the frame, put a jack under a rear shock and take out the lower shock bolt. You can lower the rear to make enough room to drill it. No need to remove the arm.
Re: Rear sway bar
I'll look when I get home, I've got a drawing I found from Hellwig I think when I did this that was very helpfull.
Dinomyte- Donating Member
Re: Rear sway bar
clanceman427 wrote:Here is the photo:
That will get you the rear bolt sir. From there just measure forward for the front bolt.
Re: Rear sway bar
I've looked high and low for what I thought I had. This is the only document I can find on the Hellwig site and it's not correct, for the previous generation
http://www.ecklerschevelle.com/assets/pdf/chevelle/608576.pdf
Sorry Damon23, I'll keep looking if you still need it
As soon as I posted this I found what I was looking for.
https://static.summitracing.com/global/images/instructions/HEL-5803.pdf
It's not exactly what you're looking for but it's what I used to get the factory holes located in the right spot for my LCA that didn't have holes for sway bar inserts, then bolted in the inserts I'd gotten from John M. and the 1" 9c1 bar I had.
hope this helps...
hope this helps...
