Disc brake dust shields
Post by wbaker01 on Thu Feb 09, 2017 4:14 pm
Started to clean my disc brake dust shields for my 73 and found some pinhole size and large rust holes..Looking for a good source of replacements or if anyone has any lying around..
Thanks,
Bill
wbaker01
Re: Disc brake dust shields
Post by fasrnur on Thu Feb 09, 2017 8:57 pm
Bill if the 70-81 Camaro spindles fit our cars, why wouldn't the dust shields from them also fit our cars.
http://www.camarocentral.com/1970_1981_Camaro_Disc_Brake_Backing_Plates_Pair_p/brc-191.htm
Street Cred : 6
Post by pila on Fri Feb 10, 2017 12:09 am
Not sure if the '73 is the same as '74-'77..I have a pair from a '75 Chevelle/El Camino..sand blasted and painted black...
Post by wbaker01 on Fri Feb 10, 2017 1:00 am
Thanks for all of the replies..
pila, PM sent..
wbaker01
Post by newmexguy on Sun Feb 12, 2017 9:11 am
73-77 A, 70-81 F, 75-79 X and 77-90? B all share the same steering knuckle in many cases - so why wouldn't the dust shield also be the same? Exceptions might be the "fleet" suspension on so equipped B bodies that had 12 in rotors and 5 x 5 bolt circle with 1/2" - 20 wheel studs.
newmexguy
Post by brownbomber77 on Sun Feb 12, 2017 9:50 am
I know I have a set from a B body but I'm not sure if the bolt holes line up. Can you post a couple measurements of the bolt holes? If you're that far, may as well put some big brake spindles on that thing...ha
brownbomber77
Street Cred : 4
Post by wbaker01 on Sun Feb 12, 2017 12:55 pm
All good options but I have a set coming from pila, thanks!
wbaker01
