Pedal assembly Help!!!
I need some help with where the brake light button needs to be located, i took it off and forgot where it goes i know its my mistake but i really need some help. Any advice or pictures would help.
JF74chevelle- G3GM Member
Re: Pedal assembly Help!!!
This is from an earlier year, but you should be able to find a hole that the brake light switch goes into on your car.
There should be a plate with a hole in it with treads that the switch screws in to, it sits so that the little knob on the switch touches the brakepedal arm a little higher than midways up. It works so that the knob is pushed in as long as the pedal is not Being pushed on. As soon as the pedal is moving the knob is released and the light comes on. It should be straight forward locating the plate.
Hs1973- G3GM Enthusiast
Here's a large pic. The sensor does screw in, IIRC to the smaller hole in the pic (mine is a 1977)
Thank you very much!!!77mali wrote:Here's a large pic. The sensor does screw in, IIRC to the smaller hole in the pic (mine is a 1977)
Yep...and, that larger hole above it is for the cruise control vacuum dump switch.
You're welcome JF74.
Steve- Thanks, now I know what that larger hole is for if I ever get a cruise control set up. Got any pics of that switch? Now ya gots me curious.
