Upper control arm bump stops
Post by KC77Monte on Wed Feb 22, 2017 8:47 pm
Getting down to buying the final parts for the front end rebuild and needing bump stops for the upper control arms. Which ones work/fit and what don't? What did you guys find/buy for yours? Do ones for 70's model GM trucks work? Thanks
KC77Monte
KC77Monte
Re: Upper control arm bump stops
Post by dynchel on Thu Feb 23, 2017 9:47 am
Just bought these from energy Suspension. Upper & lower for a '70/'81 Camaro are what you need
Post by dynchel on Thu Feb 23, 2017 9:49 am
I bought red, but they available in black
Post by Joe73 on Thu Feb 23, 2017 10:23 am
KC, I found that the uppers your asking about were pretty much a pain to install for me. They were energy suspension. I fought with them for quite a while and used lots of lube on them. They finally went in. I dont recall the part number but if I remember correctly they also fit a camaro like dynchel stated.
Street Cred : 71
Post by dynchel on Thu Feb 23, 2017 11:30 am
Joe73 wrote:KC, I found that the uppers your asking about were pretty much a pain to install for me.  They were energy suspension.  I fought with them for quite a while and used lots of lube on them.  They finally went in.  I dont recall the part number but if I remember correctly they also fit a camaro like dynchel stated.
Interesting, I lubed mine up with silicone paste, any pulled them though (the top) with plyers, went right in.
Post by KC77Monte on Thu Feb 23, 2017 11:43 am
Thanks Guys. Found the part number for the camaro listed on the energy suspension site and found them at rockauto and placed the order. Thumbs up
KC77Monte
KC77Monte
Post by brownbomber77 on Fri Feb 24, 2017 1:16 pm
Yep, that's all I put on all of the control arms I do. They hold up a helluvalot better than the rubber ones.
brownbomber77
Street Cred : 4
