Fuel injection is on!!
+4
8 posters
I decided around Christmas time to install fuel injection on my ride. A newer company called Fitech had a $100 rebate so for $800 I got mine. Finished installing using there fuel command center for the fuel and started it up today. I gotta say it is nice to just turn the key at any temperature and it idles and runs like my new truck.
bitterfitter- Donating Member
Re: Fuel injection is on!!
Sounds good & looks good ! Fuel injection sure works better than the carb mixing valve that's 100+ years old !!
I believe Fitech was used on Johnson/Evinrude outboard motors a few years ago, and maybe still is. That company was bought by Bombardia some years ago. That company is Canadian, Skido, Learjet etc...
Last I knew they are in Riverside CA. Claim to be designed and engineered in USA.
My father has a 383 in his 66 chevelle, with the old edelbrock xc8 cross ram intake manifold. Im trying to convince to convert to FI TECH. 2x4 setup. We went to a local speed shop a few days ago, and was offered the setup and the needed items required to convert his low pressure pump and fuel cell for $2000.00. He still has a few hangups, but im still trying to convince him. I think it would really be good for his setup, but i have no real world proff, or friends using any fuel injection conversion. Could you give some insight to your install?
Bruisr- G3GM Member
Looks great Bitter. Does that unit control the timing also? Looks like you've got the hydroboost up and running.
73ss- G3GM Enthusiast
I have the 1200hp fitech and loved it. I ran e85 on an 11:1 454 with a aeromotive stealth tank. Im trying to sell it now and buy the dual quad setup for an 8-71 blower im going to install (not on the same 454 tho)
BlackChevelleSS- Management
Looks great! Need a brand new tank with Stealth system installed to keep the fuel coming?????
74Malibu383- Donating Member
Install is very easy. I used the Fitech fuel command center. Easy weekend job put I took a few nights as I wanted to run all the wires in my looms and solder all connections. I also rewired my relays for my electric fan to run off the EFI. So far the tuning has been a snap also.
BlackChevelleSS wrote:I have the 1200hp fitech and loved it. I ran e85 on an 11:1 454 with a aeromotive stealth tank. Im trying to sell it now and buy the dual quad setup for an 8-71 blower im going to install (not on the same 454 tho)
Holy Cow!
Hi Dan!
Good to see you.
(Sorry for the interruption )
Roadcaptain S3 wrote:BlackChevelleSS wrote:I have the 1200hp fitech and loved it. I ran e85 on an 11:1 454 with a aeromotive stealth tank. Im trying to sell it now and buy the dual quad setup for an 8-71 blower im going to install (not on the same 454 tho)
Holy Cow!
Hi Dan!
Good to see you.
Hey I lurk daily, just rarely post.
Thanks! So far it starts and runs like a new car.
Glad to hear your happy with, im trying to convince my father to do it. I think its the way to go. After i finish my electric fuel pump install, I ve got an edelbrock cross ram for my big block im going to install. Maybe one day ill convert to the dual quad fuel injection myself.
Bruisr- G3GM Member
