Not a G3 problem, but need tranny help
Post by 77camino on Fri Mar 24, 2017 11:31 pm
Need some help. Does anyone know much about a 60's 3 on the tree tranny. I was asked to try to find some ideas as what could be wrong. It hangs up and won't go into any gear, then all of a sudden it goes in and everything seems fine. It's on an original one owner 70k 65 Impala, that has not been messed with at all and definitely has not been "hot rodded". I have not personally seen it when it is acting up. Any suggestions.
Re: Not a G3 problem, but need tranny help
Post by REVINKEVIN on Sat Mar 25, 2017 12:02 am
There is a lot going on with rods and linkage to make those work. Start at the top. Does the shifter move freely and the collar move on the steering column? Start working your way down the system and make sure old cotter pins aren't binding up. Clean all points and lube where the linkage mates up to other pieces. How is the clutch?
REVINKEVIN
Post by pila on Sat Mar 25, 2017 12:14 am
Been there... The problem may be the play in the bottom of the column, where the two arms for the shift rods are connected, and the column shift rod selects which arm to shift etc, when it's moved up & down. And sometimes It can't be shifted into neutral etc, or it's in gear, and the shifter is in neutral while one arm & rod are in gear on the trans.
Kinda doubt is any parts are available now, but there were parts to fix that problem in the old days. Maybe the bottom of the column could be taken apart and the worn parts fixed, built up with weld & re-shaped etc. It's the only way now, that I'm aware of....
Good luck with it....
Post by Hs1973 on Sat Mar 25, 2017 6:12 am
Or the clutch is worn out to a point where it only just Barely works. Can the clutch be adjustet? Does it bind up even when the engines off, or only when running. If its ok when the engines off but binds when running, i would look at the clutch. If it binds both times its more a linkage issue i would emagine.
Street Cred : 4
Post by clanceman427 on Sat Mar 25, 2017 7:17 am
Pilot bushing worn out would be a possibility. If the car can be shifted thru all the gears, using the clutch while engine is off, but it won't allow you to get into gears while using the clutch with the engine running, I'd say pilot bushing.
Find out when it hangs up to help narrow Down the possibilities.
Post by 77camino on Sat Mar 25, 2017 9:33 pm
The clutch is fine. It shifts smoothly when not hung up. When it does hang up it does not matter if it is running or not.
Post by fasrnur on Sat Mar 25, 2017 10:16 pm
I would lean towards the linkage at the bottom of the column being worn out myself.
Street Cred : 4
Post by McCauley5983 on Sun Mar 26, 2017 4:40 pm
The column and linkage wears out that's why so many get converted to floor shifter
Street Cred : 13
Post by pila on Sun Mar 26, 2017 11:18 pm
YUP !!
