Quadrajet
Quadrajet
Laguna has a Quadrajet (600) on it that is SHOT-buying the GMP 350 crate long block soon. Have two Eddy intakes to choose from and will use one of those, my question is: what is a reasonable price to rebuild the QJ? a new carb comparable to this one is 300-350 bucks- You guys know I've been a mustang guy for a few years and haven't a clue what a rebuild should cost nowadays. When I was a kid (LLLOOOOOONNNGGG time ago) the carb was $150 and a rebuild was reasonable at $75- But then again, the Grand National was the baddest new car around, taking on the Monte SS,Mustang GT, and the IROC Z-28, all pushing a whopping 175 horsepower. God, 80's cars were wimpy from the factory.
What about the QJ fellas?
Re: Quadrajet
Rebuild kits for the Q-jet are not that bad if you want to rebuild it yourself.
The q-jet is finicky about float level and secondary spring adjustment on the air valve butterflies. This spring adjustment is where most of the bog problems come from.
Then make sure you epoxy over the plugs on the bottom of the main body or else the carb will drain out in less than 48 hrs.
It is a great carb for the street. It is just more time consuming to custom tune to a specific engine
Re: Quadrajet
bigredlaguna wrote:Rebuild kits for the Q-jet are not that bad if you want to rebuild it yourself.
YES Epoxy the main plugs. We have a 72 chevy at the shop thats all original with a Q-jet. The plugs leak and empty the bowl and its a PITA to start after about 3 days. (granted it only gets started once in 3 weeks)
Oh and I hate Q-jets they are a PITA to fix and diagnose, but they do run good. I recommend a holley....
BlackChevelleSS- Management
Re: Quadrajet
Get the book by Doug Roe ,Rochchester Quadrajets (Ebay) and do it your self.
The Grand National is still one of the baddest cars in the land .
Re: Quadrajet
ant7377 wrote:Get the book by Doug Roe ,Rochchester Quadrajets (Ebay) and do it your self.
Thanks
The grand national has held up well over time, and obviously outlasted many of it's peers.
