Looking for Gauges for 77 Monte Carlo
G3GM :: Classifieds :: Wanted
Page 1 of 1 • Share •
Hi! New to the forum. Working on a 77 Monte. PO put in Auto Meter Speedometer and Tack in center of cluster. However, no fuel level, oil pressure , water temp or voltage meter. Can anybody out there help? Willing to go aftermarket it need be. Any info will help thanks. Andy
Circuit Rider- G3GM Newbie
Re: Looking for Gauges for 77 Monte Carlo
It's going to be a challenge to find those small gauges without buying the entire gauge cluster. And, even those have become scarce...and, pricey. Clusters with the Fuel Economizer gauge ('75-'77) instead of the tach are cheaper and will have these gauges...but, they still bring over $100 if you can find one. On the other hand, finding/buying (4) original individual gauges are going to cost all of that, anyway. Be advised, the flex circuit on the back of your instrument cluster is different than what is used on clusters with gauges.
- Street Cred : 67
Andy, is your flex circuit board for gauges or lights??
- Street Cred : 71
1977-1977 gauge Cluster
I will be taking my cluster out in my 1975 Laguna Type S-3 at a later date should you not find one- all of mine work as they should and includes the Rare tachometer. The reason that I am taking it out is because I have a MINT one that I will be putting in, the one in it has some rust spots on the face, but works fine. I had rather have it as is than No gauge package. If you think you might be interested, I will give you first refusal when I pull it out-Thanks Mitch
Mitchell Murphy- G3GM Member
» ATP Masters 1000: Monte Carlo
» ATP 1000: Monte Carlo
» Gauges For a Lawn Tractor
» Hi this is Carlo from Italy
» A Democrat, a Republican, and a Southerner
» Power Steering Pump Recommendation
» Autometer 2 5/8" Pro-Comp Ultra-Lite #4484 Vacuum Gauge
» Pro Street design concepts
» Where are you at picture
» 76 Guna , Colorado Springs
» 700r4 trans problem?
» 73 LeMans
