76-77 headlight wiring
76-77 headlight wiring Empty 76-77 headlight wiring
Post by nowforever13 on Thu May 11, 2017 3:34 pm
i need someone to give me the most detailed description possible on what wires go where on my headlights. like... take the most detailed pictures. pictures of the wires coming from the fuse block and wires at the connectors. i got new connectors that arent color coated. and my silly hayes manual doesnt do me much good.
please and thank you in advance
nowforever13
nowforever13
76-77 headlight wiring Empty Re: 76-77 headlight wiring
Post by 77camino on Sun May 14, 2017 2:34 pm
Several of the sockets have been replaced on this harness also, but I hope it helps. It was removed from a 77 Malibu. I have 5 wires coming out of the fuse box:
Lt green-all 4 lights
Tan- low beams
Brown-parking lights
Dk blue-right turn signal
Lt blue-left turn signal
76-77 headlight wiring Img_2325
76-77 headlight wiring Img_2326
76-77 headlight wiring Img_2327
76-77 headlight wiring Img_2328
[img]https://i.servimg.com/u/f58/19/28/56/69/img_2325.jpg[/img
Don't forget the black wires from all the lights that go to both ground points on the core support.
Post by nowforever13 on Sun May 14, 2017 3:52 pm
oh my god your a life saver... going to save these to my phone if you dont mind
nowforever13
nowforever13
Post by 77camino on Sun May 14, 2017 4:11 pm
Let me know if you need a closer picture of something. There is also one more wire in that harnes for the horn, but I don't remember what color it was. I removed it because this was the wiring for my front end that is hanging on the wall. No horn needed. Lol
Post by nowforever13 on Mon May 15, 2017 3:32 am
could you do the Ds hi and lo harnesses? and perhaps the Ps sides individually? the problem is that i must have done something bass akwards because now all of my headlighs come on but one side is more dim. so im going to un do it all and redo it according to your pictures lol
nowforever13
nowforever13
Post by 77camino on Mon May 15, 2017 3:47 pm
76-77 headlight wiring Img_2331
76-77 headlight wiring Img_2332
The first picture is the drivers side. Make sure your ground Is clean and tight.
Post by nowforever13 on Mon May 15, 2017 3:56 pm
yessss your a life saver.
what happened was when i bought the new connectors something possesed me to cut the wires and splice them in. and i couldnt find where the original ground went so i had to attach it to the top of the rad plate
nowforever13
nowforever13
