93 suburban
93 suburban
Post by nowforever13 on Sun May 28, 2017 8:52 pm
so scratch the idea of the 5.3 swap.. just gonna buy her a new crate tbi 350 but i need feedback for these mods on the new motor which jegs advertises makes around 210hp out of the box. now the mods i wanna add are a performer tbi intake and performer heads running on a stock block and a replaced delphi fuel pump what kind of hp gains would i see from this?
nowforever13
Re: 93 suburban
Post by bigredlaguna on Mon May 29, 2017 12:21 am
I think you would be better off getting a different cam. This engine should have provisions for a roller cam setup. See if you can score a set of factory roller lifters and retaining hardware and get a roller cam that is compatible with your TBI.
There are some advantages to these heads for use in the suburban, they are known to produce excellent torque, and with the right cam can get into a fun horsepower range.
Street Cred : 53
Re: 93 suburban
Post by nowforever13 on Mon May 29, 2017 4:38 pm
bigredlaguna wrote:I think you would be better off getting a different cam. This engine should have provisions for a roller cam setup. See if you can score a set of factory roller lifters and retaining hardware and get a roller cam that is compatible with your TBI.
i dont really want alot of horsepower in this thing. it is a daily. BUT i also want it to have more a$$ i mean right now its at about 180hp and around 300-350 ft/lbs of torque. the new motor is advertised at 210/350tq and a 9.5:1 comp ratio i like the torque but i want that hp number to go up not really wanting to cam it though i think it would hurt my gas milage ( i need all i can get) like better flowing heads and an intake. and a dual exhaust wouldnt hurt. as it has the crappy pre-vortec swirl port heads :/ which are the most restrictive heads ever made lol just wanting ideas for a different setup but if i can i dont wanna cam the new engine
nowforever13
Re: 93 suburban
