A/C question
A/C question  Empty A/C question
Post by JF74chevelle on Thu Jul 06, 2017 1:20 pm
Can I take out the AC unit on the firewall and the compressor and all the fitting and lines and still have a functioning heater? My AC is broken and it looks ugly under the hood and I'm building a new motor I don't want hidden under all those lines and compressor.
JF74chevelle
JF74chevelle
A/C question  Empty Re: A/C question
Post by thatfnthing on Thu Jul 06, 2017 3:55 pm
Technically you should be able to, since the heater and A/C cores are separate. However, the wiring for both systems is intermixed in the same harness, and you'd have to be sure to seal up all the firewall penetrations when you remove the A/C housing, as well as the unused vacuum control lines...
Street Cred : 58
Post by JF74chevelle on Thu Jul 06, 2017 4:05 pm
Okay thank you, that is along the lines of what I was thinking
JF74chevelle
JF74chevelle
A/C question  Empty AC housing
Post by S3SS on Fri Jul 07, 2017 6:51 am
Hole in firewall is larger under AC housing vs a non-AC car heater box.
S3SS
S3SS
