In desperate need of a 73 wiring harness and all the dash parts
G3GM :: Classifieds :: Wanted
Hello all.
I am looking for the complete wiring harness and dash (complete) for my 73 chevelle laguna. It caught on fire and I wanna get it fixed. Let me know what you got!!!
allenland2000- G3GM Member
Re: In desperate need of a 73 wiring harness and all the dash parts
I have a Black 73 Dash Pad will Need Work in Speaker area Mainly but better than a Roasted one
In Two weeks I will Pulling a Complete 77 Dash if wanted that it has cracks and is Kinda Beat But again better than what is in there
Also. I think m&h electric that you could buy the harness brand new for around $ 200. Bucks brand new.
Is it an A/C or non-A/C dash? Can you live with a '74-'77 dash...or, wanting to keep it correct for '73 with the one-year only dash emblem above the glove box?
Mcarlo77. I don't really need it to be 73. But I need all of it with wiring harness for inside and engine compartment harness lights ect. Will new dashes swap and fix correctly? Joe 73. I have bought a new dash pad already. Thank you guys. Let me know.
LimeySE. Do you have a couple pics. And do you know if it will swap? Also how bought wiring harness?
New wiring harness is availeble for all 73-77. I bought mine new when i restored my chevelle, it comes with all correct colors and new fusebox etc. It is not cheap and comes in 2 parts for the dash a lower and upper part. Maybe you can just get the one part and salvage your original depending on where the fire was. All gauges can be bought same place restored originals. But again its pretty Pricey buying all new gauges. I bought it all at elcamino store.com a part of ecklers. Elcamino and chevelle shares dash and wiring etc. Hope it works out for you.
Hs1973- G3GM Enthusiast
Oh and the horn relay is hard to find since its a 73 deal only, but i Found it new at 396.com. The wiring in the engine bay is 2 seperate pieces one is engine and one is lights, also availeble new from elcamino store.
All '73-'77 dashes will swap...but, wiring harnesses will differ somewhat. What you need to specify for the dash is whether you need the A/C or non-A/C version.
Thanks guys. It used to have a/c. But I have removed that.
allenland2000 wrote:Thanks guys. It used to have a/c. But I have removed that.
Both of Mine will have the A/c Vent But will be cheap and could fab up a Plastic Block off piece and install from Behind and then Mount Dash
Allenland2000@yahoo.com. Let me know how much and do you have a pic? Also will they be complete. Glove box gauges ect?
the Laguna One is a 73 and Just Pad The other is still Installed in Car and is a 77
How much for the 77?
Let me see what Gauges I need from it when New dash gets here Later this afternoon and will Email you pics and details
Looks Like I will ONLY need the Cluster Everything else is there Remember its Cracked Alot BUT can put a Cap on it and is red
I need to Keep Headlight switch and Instrument Cluster (Just Cluster NOT bezel)
Pm me a Phone We can work it out
How do I pm on here? Sorry I can't figure it out!
allenland2000 wrote:How do I pm on here? Sorry I can't figure it out!
How did it catch fire?
Checking to see if you still Want the dash will come with everything BUT cluster and bezel I need to Keep that stuff BUT everything else Including HVAC Controls, Ashtray, and glove door will come with
