Where from factory is the stereo radio heat sink mounted and how????
Post by S3SS on Thu Aug 10, 2017 2:58 pm
Does anyone know where the heat sink for the stereo option is mounted and how's it mounted behind the dash of a 76 chevelle?
S3SS
S3SS
Re: Where from factory is the stereo radio heat sink mounted and how????
Post by Mcarlo77 on Thu Aug 10, 2017 4:55 pm
It mounts behind and upwards of the glove box liner/insert.  Held in place by one (sometimes two) sheet metal screw...but, can't recall exactly what it was attached to.
Street Cred : 67
Post by impalamonte on Thu Aug 10, 2017 5:54 pm
as I recall , mounting points are molded into the back of the dash in that area.
mounting bracket
Post by S3SS on Thu Aug 10, 2017 8:11 pm
That was my understanding. Does anyone have the bracket that holds the heat sink to the dash above glove box? Mount is there beside defog relay/timer....
S3SS
S3SS
Post by Limey SE on Thu Aug 10, 2017 10:48 pm
Mcarlo77 wrote:It mounts behind and upwards of the glove box liner/insert.  Held in place by one (sometimes two) sheet metal screw...but, can't recall exactly what it was attached to.
I believe it attach's with Clips BUT dont know the style
Street Cred : 90
Post by S3SS on Fri Aug 11, 2017 6:23 am
Hi Limey
Thats where the rear defog timer relay mounts with a sheet metal plate that the relay is attached to and than the dash as you point out. Beyondd that is another mounting point where I believe the radio sink/amplifier mounts. I need the sheet metal piece that the sink mounts to,,,
S3SS
S3SS
