Rack and Pinion conversion
Post by ratnfested on Tue Sep 05, 2017 1:43 pm
Hi all.
I want to put a rack in my Chevelle. Anyone have an tips? I know kits exist for 68-72 Chevelles and some Fbody cars. I think I want to measure the frame rail spread on those 2 models and see if they might work on mine.
ratnfested
ratnfested
Re: Rack and Pinion conversion
Post by fasrnur on Tue Sep 05, 2017 10:17 pm
Nice car sir. I've wondered the same. Here's one to check out?
http://www.flamingriver.com/index.php/products/c0007/s0010
Street Cred : 6
Post by ratnfested on Wed Sep 06, 2017 9:07 am
Thanks I will have to call them to see if they have specs.
ratnfested
ratnfested
Post by Silentknight85 on Mon Dec 18, 2017 11:03 am
ratnfested wrote:Thanks I will have to call them to see if they have specs.
Any updates?
Silentknight85
Silentknight85
Street Cred : 4
Post by bracketchev1221 on Mon Dec 18, 2017 5:07 pm
I would look into a universal rack and then modify the tie rods for what you need. My 70 is a universal setup.
Post by calsdad on Sun Dec 31, 2017 12:29 pm
If you're thinking of putting a rack and pinion setup on a 73-77 Chevelle I would start by looking at what's available for the 70-81 Camaro / Firebird. The front end suspension on the 73-77 Chevelles and 70-81 F-bodies are VERY similar. You can swap things like sway bars between the two - so a rack and pinion setup meant for an F-body - would very likely be the easiest bolt in option for the 73-77 A body cars.
calsdad
calsdad
