Cruise control
Cruise control Empty Cruise control
Post by crice63 on Thu Oct 05, 2017 4:55 pm
I'm not sure where to post this, but I want to ask about cruise control. It would be nice to have. I've been driving the el camino back and forth to Houston and New Orleans so the lack of cruise control has become noticeable.
What is the best way to get CC in these cars? I can't imagine the stock units with wiring and control is easy to find. I see from searches that the control is on the blinker stalk? And even with a stock unit, how reliable are they? Will it just break soon after I install it? Or are there other workable solutions?
Cruise control Empty Re: Cruise control
Post by Mcarlo77 on Thu Oct 05, 2017 7:27 pm
By coincidence, I have just gone thru my cruise parts that I plan on adding to the Laguna after I swap steering columns. I've got some misc. spare pcs such as the Regulator, wiring pigtail from the strg column stalk to the Regulator, vacuum dump switch/brkt and various lengths of vacuum tubing. Even have an extra strg column lever w/cruise cable off a Regal (same wiring and fit...just different look to the lever). What I don't have spares of...and, these are the hardest parts to find...are the vacuum motor (Servo) in working order and the factory Q-jet brkt that secures the cruise cable. I might have a line on a vacuum Servo. Carb brkt could probably be fitted using a modified 2-bbl one that I have. Also, don't have a spare set of speedo cables...but, those, along with the Regulator, are available aftermarket.
I have no idea how reliable these were...but, these systems aren't very complicated. About the only things that can fail are the Regulator (available aftermarket) and the vacuum Servo getting a tear in the diaphram. The wiring pigtail attached to the strg column lever can be fished down inside the strg column by removing the strg wheel and hub plate (no need to remove the turn signal switch). Wiring is pretty straight-forward using the factory pigtail. Plug cruise lever lead into one connector, hot lead into your fuse box and other end out the firewall and into the Regulator. I could get you a diagram of vacuum tubing.
I'm sure there are aftermarket setups available, too.
Street Cred : 68
Post by pila on Thu Oct 05, 2017 9:30 pm
I transferred the cruise from my scrapped '77 Elco, including the entire wiring harness, to the '75 I have. It works good yet, use it all the time, even though it's all parts from the '77 & that old...
It's a simple system of course, and no fancy gadgets with it, just tap the button & cruise ! Very Happy
Bill
Post by crice63 on Fri Oct 06, 2017 6:56 pm
All the aftermarket kits I find require some trickeration to generate a VSS. My intake is aftermarket but my carb is q-jet so I think I would rather add a stock unit if possible. What are the chances the vacuum servo could be had off an early G-body or S10? I have to mess with installing a bunch of vacuum lines anyway to get the AC back so might as well do them all together. I need to find a vacuum canister for the AC--I've been assuming I could use any of those round canisters i could find but haven't looked that up yet. I will send Mcarlo a PM
Post by pila on Fri Oct 06, 2017 9:10 pm
I have a 4X4 S10 with cruise that has never worked since I owned it. I'll look at the servo & see if it appears to be usable on a G3...
Post by crice63 on Sat Oct 07, 2017 3:25 am
There's most of one on eBay right now.  Missing the steering column switch and the carb bracket. And the vacuum canister looks just like the charcoal filter? Is this right? The transducer takes the speedo cable input so you need a second shorter cable to drive the speedometer?
http://www.ebay.com/itm/1973-1977-GM-Chevrolet-El-Camino-Malibu-GMC-Sprint-Cruise-Control-Parts-350-V8/263231946857
Post by Mcarlo77 on Sat Oct 07, 2017 11:02 am
This looks to be the correct setup that you need; except, for the strg column lever and carb brkt.  What's nice is the Servo and Regulator will have the correct mtg brackets for proper mounting locations on the inner fender (they are different among various models). I would ask the Seller to verify that the cable attached to the Servo moves freely when vacuum is applied. I don't know of any way the Regulator can be tested. The charcoal canister has nothing to do with the cruise setup.  The brake pedal assembly does not have to be replaced...only the bolt-on mtg brkt for the vacuum dump switch needs to be transferred to your existing brake pedal.  However, having the whole A$$'y will guide you as to where to mount the brkt.
Street Cred : 68
Post by Podor on Sat Oct 07, 2017 12:26 pm
My dad had a '77 Caprice wagon he donated about 10 years ago. I should have grabbed the cruse and probably a bunch of other stuff. Never though it would be desirable.
Podor
Podor
