pulse wiper bench test
G3GM :: G3 Tech :: Electrical
I have a wiper motor that purports to be pulse wipers from a 77 Sprint. I'm trying to test it before installing it. I found the bench test photo in the Fisher Body SM, but my copy only goes up to 76 and maddeningly the pictures on the CD are nearly unreadable. It seems to be indicating 2 12 volt feeds, one to jumper 2 and the other to what appears to be ground screw? And it looks like they have it being grounded to the motor case, which doesn't seem right for a bench test, where the case itself isn't grounded to anything. My motor also doesn't appear to have a red wire they indicate being used. Before I blow up a possibly good motor, does anyone have a diagram or a better pic for the bench test? I'd like to test the washer pump too but that pic is just a black square to me.
crice63- Donating Member
Re: pulse wiper bench test
This may help. It's for a vette which is wired a little different due to the wiper door. If i recall right the case is not grounded. The wiper switch is the ground and you have 12V at the wiper motor when the key is on.
https://www.youtube.com/watch?v=ERTtTH8DoCE
73ss- G3GM Enthusiast
Yes that is helpful, just to see it in action if nothing else. His still doesn't seem to line up with what the manual is saying but at least they both have two hot wires going in.
That video is for the std 2-spd wiper. How does the Pulse system fit in? If you figure it out, Clai...let me know. I've got three of them and would like to install one on the Laguna once they are tested.
I wish I could figure it out, but after looking long at mine, and testing it on the basic functions, I'm sure it isn't a delay wiper motor. The person who sent me this must have been, uh, misinformed. The 74-76 modified pulse motors are all the same. The 76 manual has only that one.
Terminals 1-5 are the same as the 2 speed motor, it's the extra two in the middle that I don't have. I was scratching my head trying to figure out where the extra harness plugs in. Do yours have 7 terminals? I don't think that 77 was the year they figured out how to do all the delay functions with 5 terminals. So I've got to find a pulse motor before I can test it!
(I don't know how to get pics of the manual into a postable image other than to use a screen shot)
Do you have the switch for the pulse wiper ? I have a wiring diagram for the pulse wiper, which includes the switch layout. It's shown in a '77 wiring diagram...
If it would help you any, PM me your email address & I'll scan it & send it... I would post it, but I'm having problems doing that for some reason...
Bill
Bill
Here is a pic of the pulse wiper motors for our cars. Â I have no knowledge of when a transition to a 5-wire pulse system came about...but, am certain I've seen this 7-wire on full size cars up thru the end of the '70's...if not the very early 80's. Â I don't think the one shown on the Wilcox bench test video even has a washer fluid pump on it?
Thanks for the picture Steve, that is what the manual is showing. The Cardone reman motors are a hundred bucks so I guess I’ll be getting one. They want a core but I don’t know if it has to be a delay core.
Bill I do have the switch, it’s the kind that turns the knob to adjust delay speed. I still need the extra harness and now a motor. I’ll pm you to get the diagram.
I found four pulse motors in my stash and decided to test each one on the Laguna. So, I installed the proper switch and ran the extra wiring harness thru the firewall. Of the four, only one was fully functional with delay and pumping action. Two others had delay...but, weren't pumping fluid. Tried a new pump gasket kit on one to no avail. Not sure why as the mechanics were functioning. I did learn there is one seal around the inner piston that isn't included in the kit and apparently is not reproduced. It could be leaking air around that and not allowing suction. Even disassembled and removed the pump/plunger assembly and tried it manually. Couldn't get it to pull fluid. I installed the good motor/pump and called it a day.
Moral of the story is beware of used motors (2-speed or pulse) if you're looking for one that still has the ability to pump washer fluid.
On my Elco, I had to go with an aftermarket pump, which appears to be a little rotary pump, but it works good...
Found a good video on YouTube on these motors. He gets to that second rubber seal at about minute 15, near the end. A few comments said they had luck soaking that seal in washer fluid for a day or so. Another person said he put a rubber band into the deep groove under the seal, causing it to puff out and seal. The seal can’t be completely dried out for those solutions to work, though.
» Five Decades?
Yesterday at 8:23 am by Iggy
» 1977 Olds 442 in MN
