Info on this stance.
Does anyone know whos car this is or have info on it, I love the stance of it and would like to know what springs and shocks they are running.
Dead Man- G3GM Member
Re: Info on this stance.
This is a Guy Called Ripsticks old 73 I am not sure what happened to it BUT IIRC it had airshocks with stockish springs I could find him on FB and let ya know
that would be great, mine are starting to sag bad, and i like the rake look like that.
I left him a Voicemail will see what he says
Looks identical to what I used to run. See pic below. He looks to have around a 3" gap between the top of the tire and the wheel well lip. You will need either shock extenders or overall longer rear shocks. Stock shocks will only give you about 1.5" to 2" of extension so your suspension will "top out" constantly with normal driving. Also, your lower control arm will be at an extreme angle which can cause wheel hop problems. But I do love that rake and ran like that for years. Here's a pic of mine before I took it apart.
https://www.youtube.com/watch?v=tptiTU9hdJE
yeah the look deff draws my eye to it, but im not wanting any kind of issues thats for sure.mine just keeps getting worse and worse lol. I have got to do something. maybe try to achieve the same type of look with big block springs or something maybe it wont be so aggressive that way.
The front stance in my pic above was achieved with heavy duty big block springs with air conditioning. The rear were heavy duty from a wagon.
after I went back with 14s and finished the rebuild I look like im a bootlegger lol. should have done the springs and shocks wile i was at it.
Spoke with Rick aka Ripsticks73 dot com as some may remember him from, He said he had if he could recall Big block with air springs front, and in the rear he had El camino springs he says
SIDE NOTE: he also has a 73 Chevelle with Guna nose n it for sale no m/t BUT other wise complete with a lot of extra parts to go with it for 1800 OBO
