Interior color??
Interior color?? Empty Interior color??
Post by S3SS on Sat Nov 04, 2017 8:11 am
My 76 olympic chevelle has the white interior. Partsplace sells a white or an off-white interior paint. Which one works? What would you recommend for interior exact match paint?
S3SS
S3SS
Interior color?? Empty Re: Interior color??
Post by clanceman427 on Sat Nov 04, 2017 9:54 am
I struggled with several SEM cans with no luck. I took my plastic part to an automotive paint supply house and they custom blended an exact interior dye match and put it into rattle cans for me.
Post by clanceman427 on Sat Nov 04, 2017 9:57 am
Another tip-.make sure you match the back side of your Item or an area that is not weathered or faded/bleached from all those years.
Post by Joe73 on Sat Nov 04, 2017 10:29 am
The off white is actually called neutral and I believe it was only used in 73 and 74. Later years used white.
Street Cred : 73
Post by Mcarlo77 on Sat Nov 04, 2017 10:30 am
Might try consulting with Hawk03. He went thru this when re-painting/dying his white interior. Also, the shade of white on a '73 is different than your '76 (yours is a brighter white).
Street Cred : 68
Post by Joe73 on Sat Nov 04, 2017 11:57 am
There wasn't a bright white in 73 or 74, only an off white called neutral.
Street Cred : 73
Post by S3SS on Sat Nov 04, 2017 1:08 pm
So the neutral/off-white was in 73 - 74? The 76 - 77 seemed to be a bright white when new...
S3SS
S3SS
Post by Joe73 on Sat Nov 04, 2017 1:17 pm
I believe so.
Street Cred : 73
Post by Podor on Sat Nov 04, 2017 1:27 pm
My '74 had white seats but black interior. The vinyl was just as white as the seats in my "77. I'm just going off memory, since the '74 is long gone (sorry for the poor lighting on the '77). Both I would consider a true white, not off white. The problem with the white may be more discoloration vs original color. Just about every panel in my '77 is a different shade depending on where the sun hit. If you're painting plastic, you may have to paint every panel to match.
Interior color?? Image112
Interior color?? Image211
Podor
Podor
Post by Joe73 on Sat Nov 04, 2017 1:29 pm
Best way to check what color anyone has is to run the numbers on the cowl tag.
Street Cred : 73
Post by S3SS on Sat Nov 04, 2017 2:17 pm
Yes I have the original GM color (11) but was looking at the pre-made rattle cans at partsplace and they show different whites with codes from manufacturer TCP...
S3SS
S3SS
Post by Hawk03 on Sat Nov 04, 2017 2:41 pm
I tried SEM Gloss White, Super White and Sailcloth White to try and match my seats, which are aftermarket Procar seats. I think either Gloss White or Sailcloth White might match the factory color. I don't have any factory pieces to compare but they look close. Super White is more beige than white.
Interior color?? 20171110
I painted the headliner and all panels Sailcloth White. Rear seat will be dyed in the spring so it will all match.
Interior color?? 20171014
Street Cred : 13
Post by S3SS on Sun Nov 05, 2017 9:20 am
What did you end up using on yours? Gloss white? Sailcloth white? I assume that latter is more flat?
S3SS
S3SS
Post by Hawk03 on Sun Nov 05, 2017 10:26 am
I used Sailcloth White on everything. I sprayed SEM adhesion promoter then a few coats SEM color and then sprayed a couple coats of SEM Low Luster clear on everything.
Street Cred : 13
Post by S3SS on Sun Nov 05, 2017 1:16 pm
Do you have to spray the clear on? I've seen people do it with and with out. Where did you purchase SEM paint?
S3SS
S3SS
Post by 77camino on Sun Nov 05, 2017 4:08 pm
Question to anyone that had dyed/painted their seats. How well does it hold up? Does it crack or anything as the vinyl flexes?
Post by 1975 S3 on Sat Dec 09, 2017 7:02 am
On the topic of interiors, i hope there is a radiophone in it to complete the trio
1975 S3
1975 S3
Post by S3SS on Sun Dec 10, 2017 4:22 pm
Hey Dave
Like this one. Have two NOS and the GM base station. Third one is a regular GM CB radioInterior color?? E353afa688d0f88ed2a3cd51ab4cf58f
S3SS
S3SS
