4 disc brakes option? El camino
2 posters
I don't found many option for my 75 El Camino. I want 4 disc brakes on it and red caliper.
I have in my list for now those Wilwood
Front # 140-11007-R
Rear# 140-11398-R
Are they really fit?
If someone try or know others options, i will appreciate!
Front # 140-11007-R
Rear# 140-11398-R
tropdeprojet- Donating Member
Re: 4 disc brakes option? El camino
Do you plan on keeping the 15” wheel? Consider using the b body spindles for the 12” rotor and then use Wilwoods 11290-R. Then you can use a blazer or camaro rear disc setup. If you’re stuck on those for a road race purpose, then yes, those brakes will work just fine.
brownbomber77- G3GM Member
I have 18 inch Boss wheels.
I know that kind of swap but i want everything new ready to install bolts on.
» Rear Disc Brakes.
» 4 wheel disc brakes and 12" front rotors
» El Camino Wilwood rear brakes question?
