When to use tubular A-arms
I did not want to high jack the existing thread on who uses what tubular A-arm. My question is more of when is the upgrade to a tubular A-arm worth it, and when should one stay with the stock units.
As you know I am new here, I purchased a 1975 Laguna in late September (2017) and stored it for the winter. After some lengthy discussions with my wife on which vehicle to work on and which to drive (I have a 1978 Chevy C20 Camper Special Silverado) we decided to keep the Camper Special on the road and start with the Laguna. My fist project this spring will be replacing the leaky gaskets and rotted exhaust on the C20, then I can drive that to the local meets while I work on the Laguna.
Back to the suspension question. My plans for the Laguna are basically a little more than stock - restomod if you will. A 10:1 383 with aluminum heads and hydraulic roller cam, TH200-4R trans and 3.73's out back. The drivetrain I pretty much have figured out and only need pistons/rings to complete the short block. What I want when done is a car that looks pretty much stock, has enough power to get out of it's own way and a suspension that handles better than average. I have already picked up a set of 1969 15x8 Corvette Rally wheels and plan on putting a 255/60R15 tire on them, I also plan on upgrading the rear control arms to Global West system so the rear suspension will move like it was intended to without binding. I will also run a 1-1/4" front sway bar and 7/8" rear.
On the front, I am not sure upgrading to tubular A-arms is worth the expanse on what I am doing, but am open to suggestions and opinions. I know the front suspension on the 1973-1977 A-Bodies is the old tried and true suspension used on 2nd gen F-Bodies and was the design basically stolen from the C-2/C-3 Corvettes so in stock form is no slouch! I also realize that tubular A-arms are stiffer (flex less) than the stamped steel stock A-arms therefore hold the intended geometry better. I personally do like to drive a car to its limits and have owned Corvettes and even an early Trans Am, but was always amazed at how well my 1977 Monte Carlo handled for being such a big car, and still rode much nicer than the Corvettes or Trans Ams. The reason for a Laguna is I am getting too old to get in and out of a Corvette (touch of arthritis) and the swivel buckets make getting in and out very easy!
Now that you have a pretty good background on the direction I am headed, what I would like to know is at what performance level (handling) is it a benefit to step up to tubular A-arms? I know for the 1972 and earlier A-Bodies and 1978 -1987 G-Bodies they benefit even in stock form because of their lousy geometry - which is why there is a lot more offerings for those cars. I am not going with nor am planning on using larger diameter rims as I like the look of the Rallies on the Laguna and will not be road racing it. At a minimum I would use stiffer bushings, and can guarantee it will be driven more like a Corvette than a family sedan!
Iggy- G3GM Member
Re: When to use tubular A-arms
Iggy wrote:I did not want to high jack the existing thread on who uses what tubular A-arm. My question is more of when is the upgrade to a tubular A-arm worth it, and when should one stay with the stock units.
I have spoke to a few guys on this subject and that is why I decided to keep the stock control arms. Even if you are going to be doing pro-touring you could still keep these arms and they’ll be great. I spoke to Sean the guy that build the bank robber special Chevelle and he uses his stock control arms along with global west offset shafts. And that is the route that I decided to go with.
JF74chevelle- G3GM Member
For what you want to do, the stock arms are fine. The stock arms are a very stout and well designed piece. You will have more roll from the 255/60 sidewalls than control arm deflection. Like you said, put a better bushing in, and that will eliminate the bushing deflection. That will be all the suspension help they will need.
Thank you for the responses, I was pretty sure that is the route that I needed to go - stock units. I know aftermarket companies are in the business of selling parts and always hype their product over stock units. That is why I wanted your opinions.
Iggy- G3GM Member
http://www.cecilcountyphotos.com/racing-photo-gallery/2017-photos---coming-soon/9302017/?image=270e262407bef24d4317c59ca0a5bc56#photo=270e262407bef24d4317c59ca0a5bc56
Shhhh!!!!
This is stock control arms with 20 year old rubber bushings!!!
Shhhh!!!!
i would only get tubular arms if you are on a serious weight reduction program or you need the space for bigger wheels.
i had some SPC lowers and uppers on my s10 and the uppers were nice but the lowers were a little bit disappointing.
I had TRZ 2g camaro lowers on my old 73 chevelle and those are pretty nice and very light but not really intended for driving around on the street.
i think your best bet is stock arms with new bushings depending on your goals and budget. stock rubber, poly, or del-a-lum.
TrendSetter- G3GM Member
I realize this is an old thread, but none the less, it is a topic I am serious about and only took me twenty years of asking the question before I felt I knew the truth. I personally feel all tubular control arms will be heavier and more rigid while not changing geometry at all. They may do a job of hyping their products, but rarely do I read a statement regarding a change in geometry. If someone states that they have weighed the components and the tubes they purchased are lighter, I choose to believe them, and feel they should consider themselves fortunate. My choice in setting up the front suspension: An imaginary line drawn through the upper and lower ball joints and intersects the ground is called, King Pin Inclination angle (KPI) or Steering Angle Inclination (SAI). This can be found on the print out you receive from your alignment tech. I feel the Caster should be set at 1.5 - 2.5 degrees greater than SAI, or KPI, for faster camber gain as well as a couple other good reasons. This is typically acheived by moving the upper ball joint rearward, and now your wheel/tire may no longer be centered in the wheel well. As stated earlier, we do have great geometry, and these parts are not cheap. I find we can usually buy a custom chassis for less than the sum of the parts on them. Those of us with a 73/74 Sprint/El Camino also have a fully boxed frame. Those of you with 73/74 A bodies may want to purchace a frame from one, and cut the wheelbase down. Remember to slice the frame diagonally (long diagonal) or sideways V-notch to increase the area under the weld bead, or add long plates on all four sides (why add all this weght just to look like a scab). Of course, it was mentioned in an earlier post that one can buy offset cross shafts to achieve an offset. How bad do you want to beat that Porsche or Vette in the corners. Solid or polyurethane bushings are something most owners of street machines regret. 1 more thing Viking is the best value in coil overs, and the more adjustability you have in a suspension, the greater the odds that it will be way off (worse than stock).
kkairn- G3GM Newbie
Pretty much any good aftermarket arm should offer revised geometry.
How much better and will you notice is another question.
My 73 wagon was white knuckle driving on the highway because I couldn’t get enough caster with the stock arms so I got a set of upper arms from pro touring f body because they move the upper ball joint back from stock.
The trz arms also move the ball joints around for the same reason.
Another way to tweak geometry is longer ball joints. I have +1” for the uppers and lowers in a set of trz arms for one of my wagons being set up for drag racing to get the additional suspension travel.
If you’re just gonna drive around on the street with a tire that is higher than 200tw I think aftermarket arms are a toss up and very driver specific on value.
