Heater vacuum fittings
Heater vacuum fittings Empty Heater vacuum fittings
Post by JF74chevelle on Tue Feb 27, 2018 2:35 pm
I took my a/c off the firewall because it didn't work and I want to know if I need the vacuum fitting that is behind the carb on the intake manifold? I was planning to run my PVC to that port if I don't need it for my heater.
JF74chevelle
JF74chevelle
Heater vacuum fittings Empty Re: Heater vacuum fittings
Post by Joe73 on Tue Feb 27, 2018 2:39 pm
As long as the fitting is 3/8 in in diameter at the carb base plate or below you can use it for your PCV
Street Cred : 73
Post by bracketchev1221 on Tue Feb 27, 2018 3:03 pm
Yeah, into the base plate of the carb is fine. May be better to put the power booster to that port, if its tee'd off something else.
